Real time ignition help
Old Feb 12, 2016 | 02:33 PM
abosely's Avatar
abosely
My 92' 4.9L suddenly seems to have no spark. It died just as pulling in to drive and wouldn't start, opened hood to check for any obvious wires loose, got in and it started right up. Shut it off and started it couple times fine. Came back little later and no start, turns over fine and seems to be getting fuel.
It seems to have no spark. Is the coil the likely problem? Is there a way I can test it? What else should I check?
Any suggestions would be most appreciated, it's my only vehicle currently, so really need her back on the road. :-)
Cheers, Allen
Old Feb 12, 2016 | 02:41 PM
rla2005's Avatar
rla2005
Part 1 -How to Test the Ford Ignition Control Module (Fender Mounted)
Old Feb 12, 2016 | 02:44 PM
pcurtice's Avatar
pcurtice
Part 1 -Ignition Coil Test -No Spark No Start Tests (Ford 4.9L, 5.0L, 5.8L)
Old Feb 12, 2016 | 03:06 PM
abosely's Avatar
abosely
Thanks much! That should help me solve the issue. :-)
Cheers, Allen
jones189
Aug 6, 2009 09:16 PM
Wynn96
May 11, 2008 02:15 PM
hush210
Nov 14, 2006 07:58 PM
xshawx
Oct 30, 2004 07:05 PM
speedwheeler
Jan 2, 2004 10:03 PM
