8.8 diff cross pin retaining bolt broke. Can't remove pin
Old Feb 12, 2016 | 11:25 AM
UNTAMND's Avatar
UNTAMND
I have done what I can to not grab the cutting torch and chop this thing out...
The differential cross pin retaining bolt, has broke in half. I have all the threads, but no pin. The cross pin is snug and I can't move it back and forth with my fingers so it's making this job even harder. I've gotten these out with a magnet or small pick before, but the cross pin always wiggled.
How can I get this out without losing my mind?
I currently have axle out and standing on it's end, hoping gravity would help, but without the cross pin moving freely, it is a little difficult.
Old Feb 12, 2016 | 12:00 PM
Freightrain's Avatar
Freightrain
Uggh, the ultimate taboo of working on an 8.8. The dreaded cross bolt.
Try a little heat from torch to open the clearance a bit? Might get a little messy if you get too hot and the oil catches fire.
Old Feb 12, 2016 | 12:07 PM
danr1's Avatar
danr1
Yea that is a problem made worse by a cross pin that won't work with ya a little bit.
Short of getting a line on it so as can drill what's left that torch is probably looking pretty good at this point!
Might try tack welding a nut to the end of the cross pin for something to put a wrench on, or short bolt for something to grab. tacking something to it wouldn't hurt the pin and easily removed after the fact.
Being as its up ended have gravity working for you tap on the carrier causing a little bit of vibration maybe persuade whats left of that little pin to fall out? ....yea you probably tried that though!
Old Feb 12, 2016 | 12:19 PM
Freightrain
Ya, using a stick welder, put the rod in the hole and touch the broken pin. It should tack itself enough to use the rod to pull it out. Even a MIG gun might work. Worth a try.
Old Feb 12, 2016 | 12:35 PM
Puddy's Avatar
Puddy
I feel your pain.
Old Feb 12, 2016 | 02:04 PM
Ron94150's Avatar
Ron94150
Don't torch it. Get a dremel and cut off wheel. Cut edge of pin straight through the bolt. Then you can pull pin and remove carrier. Once the carrier is out you can get the remains of the bolt out easily. You will get into the carrier some. iTS OK!! I have done this. Had it out in 10 minutes. Rear end still in truck todayName:  photo103.jpg
Old Feb 12, 2016 | 08:39 PM
Ron94150's Avatar
Ron94150
Btw, that bolt is only threaded on the head side. The parts store keep the Dorman brand replacement in stock. If the cross pin has any wear, order a new one. This is the main cause of slack in the differential.(that clang from the rear end when going to drive or reverse)
Old Feb 13, 2016 | 09:51 AM
UNTAMND's Avatar
UNTAMND
I got a long drill bit and made a drill pilot, now to acquire an easy out and pull the pin out. It's got some pressure on it for some reason.
Old Jun 25, 2025 | 03:05 PM
bbford352's Avatar
bbford352
4th Gear
This worked
I ended up drilling a piece of rod and the broken off threaded section of the pin, silver soldering the drill bit I used to make the holes in the end of the rod, then threaded the broken pin back in the hole as a guide and drilling about 1/4 inch in and used an ez out. Of course after the fact I found that this Kit from Yukon was available Part # YT BE-01. But, it's out now.
Old Jun 25, 2025 | 07:38 PM
UNTAMND's Avatar
UNTAMND
Originally Posted by bbford352
Of course after the fact I found that this Kit from Yukon was available Part # YT BE-01. .
this is exactly what I made for fixing the issue I was having. They didn’t have this 9 years ago when I needed it. LoL
Old Jun 26, 2025 | 06:42 AM
Soup bean's Avatar
Soup bean
Same idea as the one from Yukon, but I think it came from amazon.
Old Jun 26, 2025 | 10:33 AM
bbford352's Avatar
bbford352
4th Gear
Mine broke with almost exactly one thread still attached to the pin. I could get a small magnet on it trying to pull it out and see it wiggle as I shifted the pinion shaft back and forth but, it would not pull out even when I drilled it with a left hand bit I still had to use the ez out.
Old Jun 26, 2025 | 10:37 AM
bbford352's Avatar
bbford352
4th Gear
LOL, Yep I found the kit the day after I made what I had work. At least it only cost me some time not the 50 to 100 bucks I found it for on line.
longm
Sep 27, 2011 07:39 PM
shoundog
Feb 6, 2008 05:49 PM
packrat56
13
Mar 27, 2007 05:44 PM
sancochojoe
Apr 1, 2004 06:47 PM
rebellforever
Jan 1, 2003 04:47 PM
