Another Caster Camber Bushing Question
Old Jun 24, 2025 | 06:10 PM
Duke5A's Avatar
Duke5A
There has got to be a thousand threads in this forum and I apologize for starting another.
I'm doing a complete front end rebuild of my '92 RWD truck and I'm looking at Moog C822 springs to raise the front end. Front end is apart now. I already rebuilt the entire back end of the truck last year with a one-over stock leaf pack. Trying to level the truck out, but it doesn't have to be perfect. Is there a preferred adjustable range I should order for this application, or is this something that can only be determined by and alignment shop once it's all together? Truck has 235-75-R15 on it now and I'll be going 265-75-R15 at a later date if that matters. Thanks guys.
Old Jun 25, 2025 | 06:25 AM
manicmechanic007's Avatar
manicmechanic007
Correct
You need to get it all put back together and then read the camber / caster with an alignment machine
It probably will need to be re cammed
Put the new bigger tires on it before you go to get it aligned
It will make a small difference with a different size tire for the alignment
Old Jun 26, 2025 | 11:20 AM
Duke5A's Avatar
Duke5A
Thanks Manic. I'll put it back together with the original bushing if I can salvage it for the trip to the alignment shop.
FoMoCoFan52
Sep 13, 2015 04:52 AM
hooler1
Mar 21, 2012 07:50 PM
Celicadude
Aug 31, 2006 11:10 AM
89broncoidlehigh
Jan 11, 2006 09:24 AM
