Removing pulley on smog pump on 460
Old Feb 12, 2016 | 10:28 AM
mwilliams0326's Avatar
mwilliams0326
My smog pump is seizing up on my 1988 F350 460. I would like to just remove the pulley and run the shorter belt bypassing the pump. Is there a special tool to pull the pulley and just leave the pump in place or is it just a few bolts? Thanks a bunch!
Old Feb 12, 2016 | 10:56 AM
Lead Head's Avatar
Lead Head
3 10mm bolts if I remember correctly.
Old Feb 12, 2016 | 12:43 PM
mwilliams0326
That sounds easy enough. I'm just not ready to take everything off yet and need to get truck back on the road. The pump is seizing up and slipping the belt.
Old Feb 12, 2016 | 06:32 PM
ArdWrknTrk's Avatar
ArdWrknTrk
pedant
6x1mm bolts, with 10mm heads
Old Feb 13, 2016 | 10:43 AM
mwilliams0326
Do you have to actually remove the pump to get the pulley off or do these bolts just hold the pulley on? Im assuming there is enough clearance for the pump to stay and use the shorter belt to bypass it.
Old Feb 13, 2016 | 10:53 AM
DeathRangerofDeath's Avatar
DeathRangerofDeath
You can remove the pulley with the pump on the truck. Very easy job. Literally 5 minutes start to finish. I can post up the belt length I used later today, don't remember it off the top of my head, searching this forum will also get you the answer.
Old Feb 13, 2016 | 06:31 PM
mwilliams0326
Got the shorter belt size from other forums. Crawled under truck and see the 3 bolts...looks super easy. That will be a welcome change from all the other problems I'm having with this truck! LOL Thank you for the advice!
Old Feb 14, 2016 | 09:53 AM
mwilliams0326
Ok dumbest question ever...I left the belt on to loosen the bolts but the pulley is still wanting to spin when I try to loosen a bolt. Is this a 2 wrench job? Any other tricks? I'm sure it's something really dumb I'm missing.
Old Feb 14, 2016 | 10:40 AM
Lead Head's Avatar
Lead Head
Probably a two wrench job
Old Feb 14, 2016 | 06:38 PM
DeathRangerofDeath
I believe I used a small pry bar/screw driver leveraged between 2 bolts to hold it still.
Old Feb 21, 2016 | 12:51 PM
mwilliams0326
Got it off! Thank you so much...very easy job. Too bad everything isn't that easy!
Chris0611
13
Oct 5, 2014 11:09 PM
sowaxeman
Dec 12, 2010 04:55 PM
scottie2hottie
Apr 6, 2008 09:16 PM
bluestarva
Dec 28, 2004 11:31 AM
