1978 - 1996 Big Bronco
Steering column binding
Old Feb 12, 2016 | 08:55 AM
arkredneck's Avatar
arkredneck
Today my steering column stated binding up in my 78 bronco. It's got a little play in it. I looked at toms bronco parts and jeffs bronco graveyard and didn't see any rebuild kits. Any ideas?
Old Feb 14, 2016 | 08:09 PM
Encho's Avatar
Encho
The Southernmost Mod
Yeah, there are 2 spots where the column might be failing, either the bearing or the u-joint. You might need to check those, I'm just guessing the setup is the same as on the newer Broncos, so those are the items I've seen. My guess is the bearing, and you'll need a steering wheel extractor for that.
Old Feb 14, 2016 | 09:27 PM
arkredneck's Avatar
arkredneck
I figured it was a bearing. I was just looking for a "rebuilt kit" so I didn't have to buy separate pieces from ford
Old Feb 14, 2016 | 11:22 PM
Encho's Avatar
Encho
Not much to rebuild there, just extract the old bearing and use it as a sample to get a new one, get a quality part (Timken, Koyo, etc...). And from now on, try not to pull yourself on the truck using the steering wheel, it's usually that (and age) which kills the bearing.
Old Feb 15, 2016 | 08:53 PM
FourXFord2's Avatar
FourXFord2
I found the bearing at macsautoparts.com. There are 2 different sizes so measure before you order. You are sure it's in the column though? disconnect from steering box to be certain.
Jmwinter
32
Nov 29, 2025 06:30 PM
BM19
19
Jul 26, 2016 07:57 PM
Mikeleew
Dec 25, 2004 09:20 PM
Ratsmoker
Jan 29, 2004 06:00 AM
