I think I asked this a long time ago but the FE population has exploded since then so I'll as it again.
My steering wheel moves up and down in the column. It doesn't slide in and out or anything but it is annoying. I took it apart and the brass bushing thing is shot. Is there a rebuild kit or anything I can use? I'm sure somebody else has had this problem.
I really can't figure out where it is messed up other than it moves up and down. I will take a look at the federal mogul site. They have a pretty good search engine.
mine did the same even after new berrings i had to find a metal sleeve to sandwich between the nylon berring sleeve and the steering wheel my turn signal cam and horn peices are all missing and that is what hold the top tight at the bottom check the clamp that is atached at the rag joint this holds your bottom berring tight hope this helps you mine was so bad it sheered the shift selector off inside not fun to find
i got my berrings from the local ford dealer they said they were the same right up through at least the 80's if i remember right so the 68 should be the same
