1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
Wire from cab to engine compartment
Old 02-12-2016, 08:52 AM
CG-ITS's Avatar
CG-ITS
CG-ITS is offline
Hi Guys & Girls,
where is the best/easiest location to run some wires from the cab to the engine compartment?
I need to run some wires for a remote start w/ alarm and a backup camera and was hoping your input will make this project a little easier....
Thank you,
Chris
Old 02-12-2016, 08:53 AM
MisterCMK's Avatar
MisterCMK
MisterCMK is offline
Find a grommet and poke through. You could also drill your own if you can get in there
Old 02-12-2016, 09:18 AM
DetailerDave's Avatar
DetailerDave
DetailerDave is offline
What about the pass thru wires already there? I think 6 (or 4) wires pass thru near the master cyl.
Old 02-12-2016, 09:22 AM
Sous's Avatar
Sous
Sous is online now
Received 4,471 Likes on 2,856 Posts
You can use the wires that go through the firewall that DetailerDave mentioned, you can use a grommet like Chris said, or you could drill your own hole like I did when I installed an EGT, boost and fuel pressure gauge. I went through just behind the brake pedal because I have a ZF6 manual and did not have the clutch lever plug in the firewall.
Easy to do once you get past the planning stage of the install.
Old 02-12-2016, 12:04 PM
scotttahoe's Avatar
scotttahoe
scotttahoe is offline
Old 02-12-2016, 12:31 PM
MisterCMK's Avatar
MisterCMK
Exactly. Less thinking, more doing. It is easy.
Old 02-12-2016, 12:33 PM
MisterCMK's Avatar
MisterCMK
Originally Posted by scotttahoe
The pass through wires aren't going to do him any good with the backup camera.
Old 02-12-2016, 05:41 PM
Sous's Avatar
Sous
Sous is online now
In addition, I used a small hole near the foot well on the passenger side to run my A/V cable for my backup camera. There was a grommet already there and I simply went through it after securing the cable to the frame from the rear of the truck.
Just get under there with a flashlight and have a look.
Old 02-12-2016, 10:13 PM
scotttahoe's Avatar
scotttahoe
Yep, won't work with the back up camera. Forgot he was doing that.
Old 02-12-2016, 10:33 PM
zs11SD's Avatar
zs11SD
zs11SD is offline
There is also a hole/grommet on the driver side floor. You can see it from beneath the truck. Just pull the weather stripping back, pull trim off, and pull the corner of the carpet back. I went through this hole when I wired my reverse camera. Avoids the hassle of getting the wire through the firewall and back under from there. Some back-up cameras don't have a lot of extra wire, so this shortens the path a bit as well.
Old 02-13-2016, 04:20 PM
D.Yaros's Avatar
D.Yaros
D.Yaros is offline
In my 2002 F-250 XLT SD I was able to run wires from the cab to the engine compartment behind the driver side A-pillar cover. The wires pass through right on top of the inner fender. No drilling, grommets, etc required.
Old 02-13-2016, 09:33 PM
Myyke's Avatar
Myyke
Myyke is offline
I just drilled an 1 1/4" hole where the clutch knockout would be on my '16 superduty and used a grommet.
Old 02-14-2016, 08:56 AM
msgtord's Avatar
msgtord
msgtord is offline
just pull back the carpet. Ready made for you. For the backup camera, I used a grommet at the rear of the cab.
Old 02-15-2016, 11:19 AM
CG-ITS's Avatar
CG-ITS
CG-ITS is offline
Thank you everybody for the input, this was great help in locating a usable hole that's already there.
I ended up running my backup camera and 5 additional wires through the existing hole using a new grommet for wiring on the driver side and some butyl to seal it. This way I was able to run the wires from 3 of the upfitter switches out as well as the wires needed for the alarm and the backup camera.
Thank you all.
Chris
CO Wapiti
2017+ Super Duty
60
03-13-2023 08:25 PM
Mgjfam
2017+ Super Duty
12-22-2016 03:23 PM
aggiect01
2009 - 2014 F150
07-13-2012 10:38 PM
86sixbanger
11-11-2009 01:18 AM
357fhp
01-22-2007 08:13 PM
Quick Reply: Wire from cab to engine compartment
