okay, if it's a repeat performance of a previous malfunction then we know the same problem still exists and we know it's related to heat and the ignition module so that would lead me to believe that the module is being subjected to excessive heat but even more likely you are using a TFI module manufactured from someone other than FoMoCo and that's a mistake lot's of people make so don't feel bad, there are lot's aftermarket components that work just fine but the TFI module is not one of them and I'm not too sure about the coil UNLESS you measured the primary and secondary resistance and compared those figures with factory specs to see if they are within tolerance, if they're not it can cause premature failure of your TFI module so check the coil and replace if it's not in tolerance, then replace the module with genuine overpriced motorcraft parts.
that's the ICM that you're referring too and the same applies for it as well..
I just checked and I guess the TFI is the ICM that was mounted on the distributor, mine is mounted on the inside drivers fender behind the battery. It doesnt seem like much air flow through there.
I relocated the TFI on my '88 E150 from the distributor. Anything to reduce the heat helps with operation and reliability.
did you change the coil? also check your fuel line pressure . I would go no further without changing the other 2 plugs . lots of time it's the little things that get you .
I have already replaced the coil. I did not replace the plugs because they
had been replaced fairly recently, I just pulled the ones I could
access to look at them and they all looked like new and were all gapped
properly.
It idled rough on the way home today and felt like it wanted to stall a couple
times while in traffic but it did not.
Hi NICKSAN,
I looked through the list of parts replaced/tested and did not see a TPS sensor. If the TPS is "noisy", the output to the computer makes it difficult to keep the idle steady. The reference voltage on the sensor is 5V so the output signal is very sensitive. I had a short circuit in my electrical system that affected the reference voltage and the idle got so rough that if was almost stalling at the stop light.
Check the voltage on the output of the TPS while moving the throttle (engine OFF) to see if the voltage smoothly changes with throttle opening. A needle type voltmeter is best for this but even a digital readout will jump around indicating a problem. jim
Is the TPS affected by heat as well? The van idles smooth when it is not hot.
Heat affects everything. When cold, the computer must see about 160F (+ or -, going on memory here) on the coolant temp sensor before it tries adjusting the idle. A good, general explanation of operations are here:
The throttle body where the TPS is mounted is heated by coolant so it gets heat cycled with every cold start. If the TPS develops a "bad spot", the output voltage signal to the computer will signal the wrong position of the throttle. Also, if anything disturbs the 5 Volt reference on the TPS, the output will be wrong. If the signal ground connection is bad, the output will be wrong.
The good news is testing it is simple and the wiring is easy to reach. You might test it hot and cold just to see if temp is a factor. jim
