More stalling, chime in....
Old Apr 24, 2008 | 05:56 AM
MisterDave2's Avatar
MisterDave2
Angry More stalling, chime in....
Hey Folks, the short story is this. 96-150 I6 auto. No codes, new wires, plugs, cap, rotor, fuel filter, fuel pressure etc. checked at shop, all good. Truck idles fine, will sit for long time in D or R in driveway and idle fine. Drive truck for a while, after warmed up, stop at corner or light, it stalls. I'm kind of frustrated witnthe whole thing, if you've had anything like this please add your thoughts. THANKS! DAVE
Old Apr 24, 2008 | 06:09 AM
Ron W.'s Avatar
Ron W.
Coil or ignition module may be breaking down due to heat (works harder under load) also check connectors. Good luck.
Old Apr 24, 2008 | 06:37 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
The usual scenario:
Ignition module overheats, engine dies, restarts almost immediately.
Next: Module overheats, engine dies, re-starts when module cools down-usually 1/2 to one hour.
Sooner or later, usually sooner, the module overheats, burns out...engine dies and will not restart.
1996 F150 4.9L
F1PZ12A297A .. Ignition Module -mounted on distributor (Motorcraft DY679)
MSRP: $147.84 / ftepartsguy.com price: $79.84
btw: On some, not sure about this one...you need a thin shanked TORX driver to remove the module from the dizzy.
F7PZ12029A .. Ignition Coil
MSRP: $77.76 / ftepartsguy.com price: $41.99
Old Apr 24, 2008 | 09:37 PM
MisterDave2
Thanks, as always! I'm gonna' check all this out over the next few days. These intermittent problems are always the BIGGEST pain in the butt to find.
