Sponsored by: Real Truck
Ford Factory Tow Package Includes?
Old Feb 10, 2016 | 10:52 AM
DetailerDave's Avatar
DetailerDave
My truck build sheet shows my truck has the factory installed tow package. How do I determine exactly what is included in this package? Other than a pigtail/ plug for trailer, and a frame mounted hitch? I believe there are relays in the fuse box under the hood, and a hookup for a brake controller in the cab. My truck has 4" blocks (F350 factory type) at the rear axle, and it does ride like a 5 ton truck, lol.
Old Feb 10, 2016 | 11:24 AM
nojoke327's Avatar
nojoke327
What year truck and what model?
Old Feb 10, 2016 | 11:33 AM
KCBS Smoker's Avatar
KCBS Smoker
I think it is in his signature.
Old Feb 10, 2016 | 11:49 AM
Just Strokin's Avatar
Just Strokin
from the 2016 Ford SD order guide
Trailer Tow Package – 7-wire harness w/relays & 7/4 pin connector
Old Feb 10, 2016 | 12:15 PM
DetailerDave
99 F250 4x4 Super Cab, 6' bed 6.8L V10, 4R100 trans, manual hubs/transfer case, 3.73 axles. Full time gas hog, BTW.
Old Feb 10, 2016 | 12:27 PM
nojoke327's Avatar
nojoke327
I'm using an app and there is no signature
Old Feb 10, 2016 | 12:30 PM
wrvond's Avatar
wrvond
For 1999 option code 531 for the Super Duty F-Series includes:
Heavy duty battery (gas engines only)
Trailer wiring harness (7-pin)
Heavy duty alternator (gas engines only)
Trailer brake wiring/feed kit
Front stabilizer bar (4x2 pickups only)
Rear stabilizer bar (DRW 4x2 pickups only)
Option code 535 for the F-150/250 includes:
Super engine cooling
Class III frame-mounted hitch receiver
Aux. auto trans oil cooler
Trailer hitch/receiver options:
-Super Duty F-250/350 pickups: Class IV (option code 86R)
-F-150/250 pickups: Class III (included with Class III Trailer Tow Group - Option Code 535)
Old Feb 10, 2016 | 12:57 PM
DetailerDave
TY, wrvond. That's the kind of info I was looking for. My build sheet doesn't list options, but it does show a tow package, and a HD battery. The wire pigtail does support a 7 wire connector, and it has a Kelsey Hayes electric brake controller installed. I was doing some research, and the rear suspension does include a 3.69" block with an auxiliary leaf spring, so that explains that. The truck had a class IV hitch installed when I bought it with a 4/7 pin connector.
Old Feb 10, 2016 | 01:12 PM
wrvond's Avatar
wrvond
Here's some more information you might find useful:
The base Pickup comes with a 4-wire connector at the left rear of the frame.
Ordering the "Trailer Towing Package", Option Code 531, provides the following:
  • Seven (7) blunt-cut wires at the left rear of the frame, fully functioning with all relays
  • installed (replacing the 4-wire connector).
  • Front Stabilizer Bar on 4x2. Rear Stabilizer Bar on 4x2 DRW only.
  • Trailer Brake Wiring Kit. Brake controller circuit is labeled and found in the wiring harness
    behind the removable panel under the steering
    column. In-cab brake controller to be purchased separately. Mating connector for under-dash
    trailer brake wire is not available through Ford.
  • HD 78 AH (750 CCA) Battery.
  • HD 115 Amp. Alternator (gas engine only).
Old Feb 10, 2016 | 06:04 PM
DetailerDave
My truck has at the driver side frame rail a pigtail with a gray squarish female connector, but I am unsure at this moment as to how many wires. There was a male connector that mated to the female connector that terminated in a 4 flat/7 round connector to plug a trailer connector into.
The truck side connector had the cover broken off, so I just ordered a new connector Ford PN YC3Z-13A576-CA. It is supposedly the correct part for 1999-2001 F250 SD. The body connector shows 7 male pins, so we shall see when it gets here.
Old Mar 20, 2016 | 09:15 PM
Hammer40330's Avatar
Hammer40330
What app do you use
Old Mar 21, 2016 | 05:02 AM
redford's Avatar
redford
FTE Leadership Emeritus
Originally Posted by Hammer40330
What app do you use
It is the Garage Talk App.
Old Mar 21, 2016 | 06:58 AM
nojoke327's Avatar
nojoke327
that is correct
joegeds
Jul 21, 2017 07:00 PM
ckal704
Aug 27, 2014 07:29 PM
saltbranch
All Things Towing
13
Nov 26, 2013 04:36 PM
mountaineer27
Aug 4, 2010 07:19 AM
sfd4
Jan 7, 2008 03:16 PM
