4 timing chains w a single cam
Old Feb 13, 2016 | 10:27 PM
85e150's Avatar
85e150
The SOHC 4.0 cam drive system is nuts.
The one good thing about those motors is when you open one up like that, you can simply pull it and send it to the scrappy. Almost any other 4.0 SOHC will bolt into it's place and accept your intake, exhaust, and other connections. Many served--they were in a lot of Mustangs for 10 years as well as Exploders and Rangers.
Before installation, new guides and tensioners. And keep the oil clean.
Some here report over 200k on these.
Old Feb 14, 2016 | 06:33 AM
GaryKip's Avatar
GaryKip
85e150sixmtod, I've done quite a bit of researching on the chain and the cause for the problem. The short version: The front hydraulic tensioner did not retain the oil pressure after engine shutdown. Then the plastic parts heated and wore out quicker and then the chain "rattle noise" started. This was not discovered during initial testing. The tensioners were suppose to be changed every 60K. But there's no mention of that in my owners manual. Most chains give up at 212K. Mine lasted to 213. I need to find if/where I can rent the special cam tools. If I have to buy the $220 tool kit it may not be worth the fix, since I was going to trade it this spring anyways.
Old Feb 14, 2016 | 12:04 PM
Alex from GA's Avatar
Alex from GA
I have a '99 Explorer with 270K with no engine or transmission problems. But it has the 5.0 and the 4R70W. Good luck with your repair Gary.
Old Feb 20, 2016 | 12:55 PM
85e150's Avatar
85e150
With 213 on the clock, just pry one out of a lower mile Mustang or Exploder. You gonna go to all this work and not go through it for bearings etc?
One member rebuilt one of these and described this as a "hateful engine."
Old Feb 20, 2016 | 02:43 PM
351Cleveland C4's Avatar
351Cleveland C4
Originally Posted by MIKES 68 F100
it ran like that ?????????????????
IT RAN LIKE THAT?!?!?!?
Old Feb 21, 2016 | 12:47 AM
GaryKip's Avatar
GaryKip
Yes it was running when I parked it. The only reason I started working on it was because the timing cover gasket was leaking coolant. I thought it was the water pump. but after replacing the pump I could see it was the gasket behind the pump that was leaking. The smaller chain (that is off the gear) is just for the balance shaft.
RoryTheFerret
Modular V8 (4.6L, 5.4L)
39
Jun 8, 2025 08:19 PM
SSStang
Oct 13, 2017 07:08 PM
Eric1976mi
Aug 3, 2017 07:57 AM
mobilefleet
Jun 7, 2010 06:13 PM
fishindave11
Nov 16, 2008 02:27 PM
