Door weatherstripping.
Old Feb 8, 2016 | 08:28 PM
PRIMERED79 SHORT BED's Avatar
Has anybody installed this kit before?
1987-1997 Ford Bronco and Ford F-Series Truck Front Door Kit-Broncograveyard.com
Good price, but my only question, on the window runs they have some funky ends on them.
I never payed much attention to mine, but are these the correct strips?
Its going on a 1992 f150 reg cab.
Old Feb 10, 2016 | 07:34 AM
Bump, anybody have any input on these?
Old Feb 10, 2016 | 08:18 AM
chrismd188's Avatar
chrismd188
They look like the right ones to me. $105 don't seem to bad if there oem
Old Feb 10, 2016 | 12:54 PM
RIKIL's Avatar
RIKIL
I have not installed that but am considering it. I have been looking for the window parts for a while, the weather stripping would just be extra for me
Old Feb 10, 2016 | 01:18 PM
madpogue's Avatar
madpogue
Probably not OEM. A LOT of non-OEM door/window hardware is absolute crap. Check the prices at the online dealers that support the forums (Autonation, Sunrise, etc); you might be surprised. I bought some "OEM equivalent" door weatherstrips from Dennis Carpenter once, marked as Made in USA on their web site. Had prominent "Made in China" labels when they arrived. You could also tell the quality was lacking. Returned them, contacted AutoNation and had them actually look at one on the shelf, it was marked "Made in Canada". Only a few dollars more. Much higher quality.
That said, MOST of the Dennis Carpenter products are US made and of decent quality. I bought a set of these: Division Bar/Door Glass Run | Dennis Carpenter Ford Restoration Parts for the division bar / glass run, and these: Door Glass AntiRattler | Dennis Carpenter Ford Restoration Parts and Door Glass AntiRattler | Dennis Carpenter Ford Restoration Parts for the anti-rattlers (one is driver side, one is passenger, and it's NOT indicated on the site). They WERE marked USA when they arrived, and of good quality.
I see they also have this set - Window AntiRattler Kit | Dennis Carpenter Ford Restoration Parts which includes the anti-rattle strips, and indicated Made in USA, but the division bar and glass run parts appear to be separate pieces, for whatever reason. No idea about the quality of this kit.
So contact the Graveyard and find out at least where they're made. If they're offshore, you can pretty-much assume they'll be inferior. Maybe it's a difference in the raw materials they have to start with.
Old Feb 10, 2016 | 02:09 PM
RIKIL's Avatar
RIKIL
You seem to know a bit about where to get parts...I never knew of that place before so I am going to ask a related question about buying parts...would you happen to know where I could get a transmission fluid filler tube for my E4OD? Mine bent the last time I installed the trans and I need a new one. Can't find that.
Old Feb 10, 2016 | 05:48 PM
Diesel_Brad's Avatar
Diesel_Brad
Something doesnt seem right. WAY too cheap. Just ONE belt line molding is $95. NO WAY you are getting all OEM parts for $105
Old Feb 10, 2016 | 06:16 PM
madpogue's Avatar
madpogue
Sorry, no clue; I haven't owned an automatic vehicle in decades. Junkyard might be your best bet for that part, if they'd be willing to sell one separate from the transmission.
$66 for the molding / anti-rattle at AutoNation (aka Tousley). But point taken; at that price, it's def. aftermarket, and most likely crap quality third-world aftermarket. Dennis Carpenter does have SOME good quality US-made aftermarket trim parts, but you have to aim carefully before pulling the trigger.
Old Feb 10, 2016 | 07:55 PM
stak's Avatar
stak
i have done this install several times when i used to rebuild these trucks after they where wrecked. the hard part about installing the trim is removing the old ones. the clips will fight you. you will need a small screwdriver to bend the back side of the clips. then just pop them off the door. they just clip to the door and to the door panels. the window seal just slides into the track channel. if you remove the door panel and remove the door glass it would be cake work to install the trim and window seal.
Old Feb 10, 2016 | 09:59 PM
RIKIL's Avatar
RIKIL
I have owned my truck for 20+ years and I think for the last 10 I have been wanting to replace these window parts. Looking forward to it. Appreciate all the info.
Old Feb 12, 2016 | 09:05 PM
[QUOTE=madpogue;16031095]Probably not OEM. A LOT of non-OEM door/window hardware is absolute crap. Check the prices at the online dealers that support the forums (Autonation, Sunrise, etc); you might be surprised. I bought some "OEM equivalent" door weatherstrips from Dennis Carpenter once, marked as Made in USA on their web site. Had prominent "Made in China" labels when they arrived. You could also tell the quality was lacking. Returned them, contacted AutoNation and had them actually look at one on the shelf, it was marked "Made in Canada". Only a few dollars more. Much higher quality.
My question was about the curved plastic parts at the end of the window runs, what are they for?
Thanks for the link, I'll check those out.
Old Feb 12, 2016 | 09:11 PM
FordTruckfan89's Avatar
FordTruckfan89
I've had good luck with Fairchild weatherstripping. Probably not us made, but fit and works well. RockAuto and jcwhitney sell them.
dbeast1113
13
Mar 11, 2018 04:18 PM
DieHardChief
Nov 14, 2013 12:35 AM
mgarzoli
Oct 14, 2004 12:21 PM
Dragrazor
Aug 17, 2004 11:02 PM
Gobstopper
Apr 10, 2002 05:59 PM
