Vibrations while accelerating
Old Feb 7, 2016 | 02:05 PM
KDS64718's Avatar
KDS64718
My 04 6.0 excursion recently started vibrating or shaking while driving between 40mph up to 60mph bat at higher speeds than 60mph it completely goes away, and when i let off the accelerator it also doesnt do it. Check my u joints after driving 60 miles and they seem fine any ideas?
Old Feb 7, 2016 | 03:51 PM
r2millers's Avatar
r2millers
Pull the u joint off and grease the yoke well. That will create a similar issue as described.
Old Feb 7, 2016 | 04:01 PM
WatsonR's Avatar
WatsonR
I agree with Bob. Your not strong enough to flex the yolk like the truck can... not that I'm saying your weak... just the truck can torque that thing better.
Old Feb 7, 2016 | 04:52 PM
KDS64718's Avatar
KDS64718
So i should pull my u joint and grease it
Old Feb 7, 2016 | 05:43 PM
GenMan's Avatar
GenMan
not in front of the neighbors
Old Feb 7, 2016 | 06:53 PM
jmaskew's Avatar
jmaskew
Also check the carrier bearing, the one that supports the drive shaft. See if you can move the drive shaft around. There is supposed to be a little play. I had a similar vibration and after I replaced it the vibration went away.
Old Feb 8, 2016 | 04:52 PM
jlaudiofan's Avatar
jlaudiofan
Tire balance and rotation, check air pressure? Check the simple things first
sammie0126
Dec 29, 2012 10:04 AM
openexcess
May 24, 2011 03:05 PM
JDiesel450
Feb 10, 2010 09:44 PM
Midnightride42
Dec 27, 2008 09:23 AM
