For Those Than Installed Android Radios...
Old Feb 7, 2016 | 10:17 AM
Matt M, PA's Avatar
Matt M, PA
..I'm wondering about the install itself.
According to another thread on these forums, there are units that simply replace the factory system as opposed to requiring trimming the dash.
My question is how these attach to the dash itself. Meaning, the factory radio uses the "U" shape tools that released the clips for the radio to slide out. Are these somehow re-used from the old radio? Do you remove the instrument panel surround to install these radios?
Thanks for any info guys!
I just pulled my instrument surround to refinish it when I added an iPod adapter to the factory unit...so while I'm not "afraid" to pull it again...I'm not in a rush to do it, either.
Old Feb 7, 2016 | 10:32 AM
agsmv1's Avatar
agsmv1
You may need some trimming around the panel where the radio was to get it to fit correctly. They have a sleeve that uses tabs to bend around the hole and secure to the panel. Mine actually locks into place and I have a set of keys similar to the "u" shape bolts that unlocks it and lets it slide out. Most after market radios I have installed use this setup, I would expect the android radios not to be much different than that. I went with a single din vs. a double din...didn't really know about the android radios when I swapped them, plus I didn't want to spend too much money on it.
Old Feb 7, 2016 | 12:44 PM
Oldguyfl's Avatar
Oldguyfl
There are videos on youtube showing the install on an 05.
I put one in the 03 X and it fit pretty well. No dash trimming required.
Nice unit and only $300.
Old Feb 12, 2016 | 08:41 AM
freesoul's Avatar
freesoul
Question
Which one did you get and did you use a separate install kit or did it come with one? Do you have a rear DVD?
Old Feb 13, 2016 | 09:35 AM
Matt M, PA's Avatar
Matt M, PA
...and did the dash have to come out to put it in?
Romeo Scorpion
6.7L Power Stroke Diesel
Oct 23, 2013 08:41 PM
ItStillRuns
13
Mar 21, 2013 11:22 PM
ggadwa
Apr 25, 2012 07:41 PM
Flying Finn
Aug 14, 2009 08:55 AM
rmilchman
Aug 17, 2004 12:04 PM
