Sponsored by: Real Truck
Radio Removal
Old Aug 15, 2004 | 01:35 PM
rmilchman's Avatar
rmilchman
Radio Removal
I have an '02. If I'm replacing the stock stereo with aftermarket, do I need to remove the dash to get the radion out?
Thanks,
Rich
Old Aug 15, 2004 | 01:50 PM
matt1751's Avatar
matt1751
if its like my 04 and most ford radio's then No,, there should be 2 holes on each side on the front of the radio, if you have ford radio tools then just put then in these holes and the radio will pull right out,, most auto parts or car audio shops will sell them,, if not you can use allen wrenches, use 4 that are close to the size of the holes.. insert then about 2 inches and push then away from the radio and pull out on them,, the radio should come out,,
Old Aug 15, 2004 | 02:09 PM
DS02F250's Avatar
DS02F250
Rich, you don't "HAVE TO" remove the dash panel to remove the stereo, but it actually saves time and makes the install a cinch. There's only a few plug-ins that need to be removed and re-attached, so it's not that bad of an endeavor. Once you get the dash panel unsnapped from the dashboard, you don't necessarily have to remove it all the way off. You can work on replacing the radio with the dash panel just pulled away from the dashboard. Oh yeah, and remember to hook up the antenna plug to the back of the stereo before you button it all up. Been there, done that! Dowt!!!
Good luck!
Daryl
Old Aug 15, 2004 | 02:42 PM
rmilchman's Avatar
rmilchman
Any tricks to gtting the panel off or do I just pull?
Old Aug 15, 2004 | 04:05 PM
wiingnut's Avatar
wiingnut
Taking the front of dash out isn't necessary. If you dont have a radio tool coat hangers are perfect. Most of the newer dashes pull right off, though I have never removed my super duties
Old Aug 15, 2004 | 05:56 PM
fireman28's Avatar
fireman28
I thought there was a screw the had to be removed after the radio was out to pull the dash. I may be wrong on that. I used the removal tool and had to work the radio for a minute but it did come loose. Putting the new unit in was a snap.
Old Aug 15, 2004 | 07:07 PM
rmilchman's Avatar
rmilchman
I'm buyng a pioneer and will have to install a cage so it fits the Ford. I'm wondering if the cage can be installed without the dash coming out. Question about the tool. When you insert it I'm assuming it pushes on something to trigger a release. If that's the case I'm wondering if I can use some nails.
Old Aug 15, 2004 | 07:24 PM
cableguy17866's Avatar
cableguy17866
My '04 has 2 screws above the radio that holds the dash on in that area. once you get the radio out, the screws are directly above where the radio was. Then the dash just pops off, but be careful there are just spring clips on plastic tabs that are mounted on the dash panel and I ended up breaking off one tab that was by the steering column and I was very careful. Luckily it doesn't rattle.
Old Aug 15, 2004 | 09:11 PM
matt1751's Avatar
matt1751
rmilchman, there is no need to remove the dash, I see your profile says your in Robbinsville, NJ,, I'm not far from you and if you want to e-mail me I'll give you my # and you can call me . I can explain better over the phone how to remove and install radio or I would be willing to help you if you want,,, See pics in my gallery,, I installed a Clarion in my 04,, matt
Old Aug 17, 2004 | 10:02 AM
david.brady's Avatar
david.brady
There isn't really a "trigger release" More of a tension clip that has to clear the sides of the framing. When you insert the tools only put them in about 1.5" and like said before, you want to press out so that the clips squeeze on the sides of the radio. Don't know if I really painted a picture, clear as mud?
The cage you're speaking of will more than likely require the dash out. When I did mine, I had to. It came with two screw holes to secure the cage in the factory holes. For some reason when I screwed it in, nothing matched up right again. I ended up breaking off the fasten points from the cage and putting the dash back together, then sliding the cage w/head unit together in the hole. It's not screwed in, but fits nice and snug. I've never had any problems with it moving or falling out or anything, perfect fit. Check my gallery to see the pics of the unit and dash. If someone really wants to steal it, screwing it in is only gonna take them another minute to do, if they're being careful to begin with.
Old Aug 17, 2004 | 12:04 PM
fireman28's Avatar
fireman28
I installed a Kenwood in mine. I didn't have to remove anything but the radio. The adapter kit that i got didn't require any screws. It had one bracket that you screw to the back of the radio thatlets the rear or the radio slide on the factory rail. Then the trim ring has clips that snap it into place. Hope this helps.
