Body mounts creeking
Old Feb 12, 2016 | 07:11 PM
2002exPSD's Avatar
2002exPSD
I've read threw a lot of threads concerning the body mount creek under the drivers floor board. Mine has been creeking since 60,000 miles. Have 220,000 miles now. Has anyone found a garaunteed fix yet for these little buggers?
Old Feb 12, 2016 | 07:59 PM
pirate4x4_camo's Avatar
pirate4x4_camo
There are likely a few causes but the top mount collapsing and the metal sleeve inside the bushing hitting the body seems like a popular choice. A new mount should cure it.
If it were me I would use a polyurethane replacement.
Old Feb 12, 2016 | 08:48 PM
LivingLarge's Avatar
LivingLarge
Replace it, I had tried a few methods like grinding etc.... They all just got me a month or so on my previous ex... When I replaced (OEM) and added the later on shim that also came from ford problem was solved.
Old Feb 13, 2016 | 01:46 PM
2002exPSD's Avatar
2002exPSD
How many bushings normally go out? $90 a pop is pretty step. $63 a piece with my discount.
Old Feb 13, 2016 | 02:08 PM
LivingLarge
The one under driverside feet 1st to go...
It has the most amount of stress
Old Feb 13, 2016 | 06:31 PM
DSN46's Avatar
DSN46
I replaced all four under the passenger seating area when I did mine.... mainly because I wanted to do the ones that creak the most "while I was under there".
Not a hard job, just PIA job.
LivingLarge
Aug 31, 2021 04:27 PM
DougJ_1997PSD
Jun 18, 2015 08:11 PM
GREATWHITEHUNTER
Mar 8, 2009 09:09 PM
fordboy67
Aug 6, 2008 01:56 PM
