Throttle Solenoid
Old 08-10-2003, 02:30 AM
Cablesplicer's Avatar
Cablesplicer
Cablesplicer is offline
Throttle Solenoid
Hi all,
The throttle solenoid on my '77 F250 (351M) is disconnected. After reading many old posts, I have basic understanding of what its function is. However, I am unable to find where the single electrical lead coming off of it, is supposed to connect to? Any help would be greatly appreciated.
Cablesplicer
Old 08-10-2003, 02:34 AM
Torque1st's Avatar
Torque1st
Torque1st is offline
Posting Legend
Throttle Solenoid
Some of them were connected to the AC clutch circuit to provide a higher idle when the AC compressor is running. Others were connected to 12V from the ignition switch RUN position to provide a anti-dieseling function for smogged out vehicles.
Old 08-10-2003, 11:58 PM
tetraruby's Avatar
tetraruby
tetraruby is offline
Throttle Solenoid
On my '79 I had to remove the old connector that also had a lead for the choke. The anti-diesel solenoid will be 12V with key on while the choke is around 5V with motor running. Should be along firewall where you'd expect it to be.
LARIAT 85
17
02-27-2022 04:02 PM
chapinjerau
11-13-2016 07:39 AM
LloydH
08-08-2015 08:19 AM
FilmCarp
05-03-2015 02:13 PM
Timgeorgi
09-12-2006 12:30 AM
Quick Reply: Throttle Solenoid
