I have had Val****** perform trans fluid flush? just this evening.NO PROBLEMS PRIOR!! only by mileage rec.no mil.smooth running & shifting.truck is 4x4.was dad's truck.I got in march 2015 w/25000 miles. driven approx.2 miles and stalled. restarted w/ difficulty.missing white smoke. trans fluid present at tailpipe. mil on. scan tool showed o2 sen & # 5 cyl poss injector n/g.help!
I don't know, maybe they poured the new trans fluid into the oil fill? Or somehow did this 'flush' using the oil cooler lines instead of the transmission fluid lines [if your truck has both]?
Sounds like it's really time to have it towed back to that shop and go "what the hell did you do to my truck?"
This might be a question better asked of Mark Kovolsky---IIRC flushing later model transmissions requires a specialized bit of equipment to be done properly.
I have had Val****** perform trans fluid flush?........ driven approx.2 miles and stalled. restarted w/ difficulty.missing white smoke. trans fluid present at tailpipe. mil on. scan tool showed o2 sen & # 5 cyl poss injector n/g.help!
They did something to the engine. No matter what they may have screwed up in the transmission it can't do this to the engine. Check the engine oil level. I'll bet it is WAY overfilled, and overfilled with trans fluid.
Was this a quick lube shop? Most of them employ minimum wage people with ZERO knowledge of cars and trucks, and little to no training. That's a recipe for major screw ups. But the good thing is that the ones with a nationally recognized name will have good insurance to fix things like this.
