check engine light
Old Feb 5, 2016 | 08:03 PM
Teri Brown's Avatar
Teri Brown
check engine light
Please help.
My F250 diesal check engine light came on. When it is on, I have no power. I have changed out both the fuel filter and air filter. The light them became intermittent for a short bit then shut off. I was able to take my truck for a short quick drive. Next day, emediately, the light was back on upon starting.
I am both stranded and broke without a clue as to what to do next.
Old Feb 5, 2016 | 08:08 PM
ReBilld's Avatar
ReBilld
Without a scan tool, there is no way to know exactly what the light is on for. It could be a number of things.
Old Feb 6, 2016 | 08:06 AM
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
As you already found out that won't fix what's wrong with this.
The cheapest way to fix this is to find someone that can read the codes. The auto parts stores that read codes free usually cannot read ANYTHING on one of these trucks. You might get lucky and find someone on this forum that lives near you (where are you located?) and has the tool to read the codes. Otherwise you'll need to get it to a good independent shop or a Ford dealer to read the codes.
Without the codes all we can do is list EVERYTHING on your truck, and you buy and replace each of them until it's fixed. Without the codes nobody knows what's wrong.
Old Feb 6, 2016 | 10:38 AM
BBslider001's Avatar
BBslider001
What does "no power" mean? No throttle response? It'll go, but goes slow? Until you get the codes read, it's a wild a$$ guess.
Old Feb 6, 2016 | 10:21 PM
oldbird1965's Avatar
oldbird1965
If you like to bet, odds are it UVCH's.
MikeRizz
Jan 30, 2010 07:21 PM
powerstroke02
Dec 16, 2007 12:58 PM
myEXisFAT
42
Sep 6, 2006 02:12 PM
countryfree95
Mar 14, 2006 06:02 PM
irishman200232
Jan 19, 2004 02:14 PM
