Fuel filter...
Old Aug 9, 2003 | 11:21 PM
joners's Avatar
joners
Fuel filter...
For my 351W with Holley Blue Pump. Should my filter be before the pump? Or should it be after?
Old Aug 11, 2003 | 08:14 AM
TorqueKing's Avatar
TorqueKing
Fuel filter...
you can go either, or both. Just make sure that the more restrictive filter is on the side that has the fuel "pushed" through it (after the pump).
Old Aug 11, 2003 | 05:16 PM
joners's Avatar
joners
Fuel filter...
Whats a good one to put before it? I was going to get the Fram one from summit...
http://store.summitracing.com/partde...art=FRM%2DHPG1
Old Aug 12, 2003 | 11:26 AM
TorqueKing's Avatar
TorqueKing
Fuel filter...
you should put that one upstream if you do use it, but I wouldn't use that because it's too expensive. Get a regular carburetor-style fuel filter on the "sucking" end of the pump, and on the pushing end, look up a replacement filter for a 2003 F-350 SD with a V10. It'll be a nice, large filter that should cost about $12 and will filter just as well as the Fram one will. The V10 truck filter will get finer particles out, after the carb-style filter gets the larger particles out. With this configuration, you should change the little (sucking end) filter every 6-10 thousand miles, and the larger one can go for 20-30 K no problem.
Old Aug 12, 2003 | 01:09 PM
joners's Avatar
joners
Fuel filter...
It's not to expensive. Nothing is.
For the regular carb one, you mean just an inline one?
Old Aug 12, 2003 | 04:37 PM
Cloim's Avatar
Cloim
Fuel filter...
I believe the ones hes talking about are both 'inline' style filters.
The one after the fuel pump needs to be designed for EFI so it can handle the preasures involved.
The one before the pump will only be dealing with low preasures so a filter for a carbed engine will work.
Old Aug 12, 2003 | 08:08 PM
joners's Avatar
joners
Fuel filter...
handle the pressures? it's just a blue pump, nothing fancy. heh
everything is on order though!
Roger C
Feb 16, 2017 09:57 AM
wglogg
Sep 12, 2016 10:37 PM
pgguru
Apr 10, 2015 12:40 PM
cabloom300
Sep 20, 2013 06:30 PM
hwy92truckn
Feb 3, 2013 11:28 AM
