Installing new Fuel Pump
Old Apr 9, 2015 | 05:27 PM
pgguru's Avatar
pgguru
I just got my Bosch fuel pump from Riff Faff and will be installing it this weekend.
I want to add a Pre and Post filters to the pump and had a couple of questions
1) the threaded end that's under pressure what is that connection.. I would like it hard connected to a filter and then the stock line connected to the out put of the filter.
2) for Pre Filter its a push Lock connection... Should I keep it or look for something that works better under Vacuum?
Thanks
Old Apr 9, 2015 | 06:30 PM
JuanHuevos's Avatar
JuanHuevos
Thanks
From all that I have seen with all the Hutch mods, just ditch the spring-lock line since it leaks air under vacuum and install 3/8" hose that can withstand diesel, blah blah, use fuel injection hose clamps, and then install a Racor PS-120-02 filter. I didn't do this during my Hutch but will be doing this soon.
Here's a thread you might like
Old Apr 9, 2015 | 08:33 PM
pgguru's Avatar
pgguru
Originally Posted by JuanHuevos
From all that I have seen with all the Hutch mods, just ditch the spring-lock line since it leaks air under vacuum and install 3/8" hose that can withstand diesel, blah blah, use fuel injection hose clamps, and then install a Racor PS-120-02 filter. I didn't do this during my Hutch but will be doing this soon. Here's a thread you might like
I did the Hutch mod last year and feared that the lack of screens could have taken out my pump.
I would like to drop the tank and put new lines on it clamped to the push lock connection put its dead in my driveway with a full tank
Old Apr 9, 2015 | 09:32 PM
JuanHuevos's Avatar
JuanHuevos
Ouch! That certainly isn't good. I did notice when I did mine that I was able to lower the tank and remove the lines without taking the tank all the way out. I was thinking I was going to use a floor jack to support the tank and remove all but 2 bolts just enough that it'll still hold the weight but let me squeeze my arm in. Maybe that is possible?
Old Apr 9, 2015 | 09:39 PM
pgguru's Avatar
pgguru
What two should I take out
Front, Back, or drivers side?
Old Apr 10, 2015 | 03:25 AM
JuanHuevos's Avatar
JuanHuevos
What two should I take out Front, Back, or drivers side?
I'm trying to remember... I think you take out the rear 2. It's tight but I was able to get the lines off and on this way. IIRC, I could get my head up in there and could see everything too.
Old Apr 10, 2015 | 06:41 AM
Tom's Avatar
Tom
It may have worked once, but I certainly wouldn't try it. 44 gallons of fuel weighs somewhere around 300 lbs, add to that the weight of the tank and the skid plate. There's no WAY I'd want that weight applied trying to snap the tabs off the skid plate like that.
Here's my thread on replacing the pump on my gas-powered Excursion:
https://www.ford-trucks.com/forums/1...l#post12782162
I'm sure the connections are different, but I was able to use a floor jack to lower the tank to the ground before disconnecting them.
Old Apr 10, 2015 | 12:09 PM
pgguru's Avatar
pgguru
I am still trying to figure out what the high pressure connection from the fuel pump is?
Is it just a pipe thread or is there a flair??
thanks
Old Apr 10, 2015 | 12:16 PM
Tom's Avatar
Tom
thanks
Neither, should be a quick connect fitting.
Old Apr 10, 2015 | 12:40 PM
pgguru's Avatar
pgguru
The pump from riff raff has a female threaded end
I guess I have to remove it from the old pump
tomwhatley
Sep 27, 2014 08:21 AM
hdman90
20
Jul 8, 2014 11:45 AM
pit_of_pity
May 9, 2011 06:56 PM
JonathanN
32
Jun 5, 2010 01:36 AM
misnomer
Apr 18, 2008 01:28 PM
