Filter before electric fuel pump?
Old Sep 20, 2013 | 09:03 AM
cabloom300's Avatar
cabloom300
Im working on getting my 87 6.9 up and running again. It has sat for about a year after i bought it and the Mr. Gasket pump that was on it has died so im putting a Airtex on it that i bought and im thinking of mounting it down on the frame. Should i put some sort of filter in between the pump and the tank or just keep the stock fuel filter in the engine compartment? Thanks
Old Sep 20, 2013 | 11:31 AM
Red454sedgwick's Avatar
Red454sedgwick
No filter will void the warrenty on the pump
Old Sep 20, 2013 | 03:02 PM
jayro88's Avatar
jayro88
Not sure about the Airtex, my Carrier has a metal screen filter in its fuel bowl to catch and debris. If mine did not have this screen I would run a filter before it.
Old Sep 20, 2013 | 06:30 PM
FORDF250HDXLT's Avatar
FORDF250HDXLT
Easy to Install-Easy to Service: Two bolt mounting makes installations easy. Nothing to adjust. The pump is self-priming to 120 inches (3.0 m). Vertical mounting is preferred to assure maintenance of rated pressures. The transparent housing allows for visual capability to monitor the cleanliness of the stainless steel filter.
whiteaddiction
Bio-diesel, Propane & Alternative Diesel Engine Fuels
Sep 10, 2012 02:25 PM
Shattered
Jun 2, 2012 10:13 PM
old76er
Nov 11, 2009 09:26 PM
robjs111
Jul 18, 2008 06:31 AM
killerkjn
Nov 3, 2005 02:58 AM
