Power windows work but noisy
on
81 92 Ford PU Pickup Truck Bronco Power Window Lift Motor Gear Repair Kit | eBay
Windows work in my F250 but are really noisy. Will these kits solve the problem? Anyone used these repair kits and how did they work for you. Thanks.
on
Pulled the door panel and discovered that Ford riveted the regulator on. Couple of minutes with a dremel and drill got them off. The gear was the cause of the noise. 24 years in the Nevada sun and dirt destroyed the gear internals. Bought a replacement off ebay for $11.00. The replacement gear fit perfectly. I'll use 1/4 inch bolts to retain the regulator on reassembly. The saga continues.
Bojohnson
09-27-2016 05:39 PM
Kendal
05-10-2016 12:50 PM
johnboggs21
19
05-18-2010 01:08 AM
