Six Cylinder Exhaust Manifold Gaskets
Old 02-02-2016, 07:52 PM
Mercmeister's Avatar
Mercmeister
Mercmeister is offline
Hi -
I am in the process of installing a 300 cid straight six engine in my 1966 Ford F100. I am using an Offenhauser 4-bbl intake manifold with newer factory Ford cast iron dual exhaust manifolds that connect to a Walker WLK-45166 wye exhaust pipe. My question is, do I need some sort of exhaust pipe donut gaskets between the output side of the exhaust manifolds and the Walker pipe?
Thank You!
Dan M. (aka mercmeister)
Old 02-03-2016, 03:08 PM
jack orchard's Avatar
jack orchard
jack orchard is offline
No. Also consider using the Mr. Gasket 260 intake/exhaust manifold gasket.,...jack
Old 02-06-2016, 04:05 PM
Mercmeister
Thanks Jack! I have the Mr. Gasket gasket, so I'm ready to go as soon as I paint the wye pipe...
Dan M.
Old 02-06-2016, 05:58 PM
jack orchard
Sloppy welds?
Be sure to check the 45166 pipe where the short pipe welds to the long pipe. Be sure it is fully open (not obstructed).,...jack
Old 02-28-2016, 03:29 PM
Mercmeister
Hi Jack -
Thanks for the tip! When I peeked down the Y pipe, I was surprised to see the there was quite a bit of obstruction. The manufacturer just cut a small "mouse hole" in the main exhaust pipe before welding on the section of pipe to make the Y. A few minutes with the Dremel tool took care of it, but I probably would not have even looked without you mentioning it.
Thank Again!
Dan M.
Old 02-18-2017, 08:43 AM
facepalm's Avatar
facepalm
facepalm is offline
Waliker Pipe
Originally Posted by Mercmeister
Hi Jack -
Thank Again!
Dan M.
How does the pipe fit in a 66? Even though I can't find the pipe itself, I can order it with the catalytic converter and possibly sell the converter on craigslist. Did you have to modify it at all? Thanks.
Old 02-18-2017, 09:45 AM
red66rider's Avatar
red66rider
red66rider is offline
Hi -
Thank You!
any pics of this setup?
Old 02-18-2017, 01:46 PM
jack orchard
donuts not necessary. they are flange fit. no pics.
Old 02-18-2017, 01:59 PM
NumberDummy's Avatar
NumberDummy
NumberDummy is offline
Ford Parts Specialist
1965/74 240/300 & 1975/83 300: Donut gasket as original:
C6AZ-9450-D = 2.50" O.D. x 2.03" I.D. x 5/8" thick.
Old 02-19-2017, 07:37 AM
FuzzFace2's Avatar
FuzzFace2
FuzzFace2 is online now
Received 2,128 Likes on 1,812 Posts
Not a 66 but on my 81 F100 flare side.
I did a lot of looking and could not find just the Y pipe, only Y pipe & cat. IIRC got them thru Rock auto as they were the cheapest I could find.
Where the 2 pipes joined was ok on mine and did not need to open it up.
Link to my EFI exh manifold project with pictures.
https://www.ford-trucks.com/forums/1...questions.html
ND thanks for the information but I think they were asking about the duel EFI exh manifolds if they used donuts between manifolds & pipe.
No they don't as the sealing flange is built into the manifolds as you can see in my pictures.
Dave ----
Old 07-07-2018, 03:39 PM
old28's Avatar
old28
old28 is offline
Has anyone on this thread ever used a "Remflex 3005" one pc gasket on a 240 or 300 with EFI exhaust manifolds and an Offy DP or C aluminum intake?
Some on the truck site seem to like the gasket.
Old 07-09-2018, 02:20 PM
fordman75's Avatar
fordman75
fordman75 is offline
You won't find a better gasket for sealing and not burning thru/leaking.
You'll want the 3005 if you plan to run some kind of water heat plate on the bottom of the intake. If you don't then go with the part # 3080 ( for EFI engines ) .
Old 07-09-2018, 08:17 PM
ultraranger's Avatar
ultraranger
ultraranger is offline
On my inline 300, I used a pair of '94 ('87-'96) 4.9L EFI exhaust manifolds and got a section of the pipes coming off the exhaust manifolds, back to a few inches past where the O2 sensor screwed in. The remainder of the exhaust was run from there with two separate mufflers and separate exhaust exiting out in front of each rear wheel. --I don't have any gaskets between the exhaust manifolds and the head.
The exhaust pipes where run from where these pipes left off.
Old 07-09-2018, 08:49 PM
fordman75's Avatar
fordman75
That's a good looking engine and truck!
Old 07-20-2018, 10:18 AM
worldchampgramp2's Avatar
worldchampgramp2
worldchampgramp2 is offline
Love these “best practices” threads, especially when it comes to one of our critical program content issues GASKETING. Your personal experience, openly shared on this subject, right here on this Forum and in this thread is appreciated by our team and very important to our quest for excellence/user friendly outcomes.A little History on the origin of the well-known #260 Mr. Gasket is in order. The 260 1-piece fiber composite gasket, for the 240/300 3.9 & 4.9L engines began with its public release in 1972. Way back then, my key contact at Mr Gasket, cultivated while employed by Fomoco in their Motorsports efforts, was Rich Smith. He and other aftermarket manufacturers’ key personnel routinely spoke with yours truly [Bruce Sizemore aka on our Forum as Gramps/ worldchampgramp] to “fetch” and send them genuine Ford factory production blue prints. Whether it was Crane Cams, Edelbrock, Mr. Gasket or others they all found or were directed to “Gramps” the problem solver. ALL of this took place before I was able to campaign my first notable ¼ mile ride the infamous Preparation H Maverick as none of personally could own or even drive a competitive off-road vehicle. This was a NO NO in Ford Motorsports employment and a violation meant your out-of-here.Reason for this background is the 100% accurate statement that if it were NOT for my association with Rich Smith there probably would not be a #260 gasket ever. Likewise, there was a little known one piece “Sizemore” Mr Gasket Boss 351C gasket, specifically developed for my second crowd pleasing Ford I/Gas Pinto “terror among the NHRA ranks” from mid to late 1970’s. . Both of these notable rides are summarized in a history pic format even with a YouTube Video right here https://www.ford-trucks.com/forums/1547453-entry-level-street-strip-head.html for your viewing pleasure then scroll to post #47 and #50. Our 1st product offering Street/Strip prototype is nearing completion and will ONLY BE PRODUCED with intake and exhaust port openings MATCHING readily available Ford OEM and aftermarket gaskets. A summary of what all of you have clearly articulated in this gasket/no gasket thread will be reviewed by ALL of our team members. For it is this type of hands-on direct involvement expertise shared by all of you we value and making our product content decisions. Please rest assured that when we release the next kick butt Max Flow u-head WE will offer to all a proprietary one or two piece (TBD) absolutely bullet proof reasonably priced Sizemore Performance alternative. Hey might as well place my name on another gasket product, 45 years is too long an interval…don’t you think?? Now back to my cold breakfast. Bruce
kabcpapc
1997 - 2003 F150
05-18-2019 10:34 AM
nix4x4
08-20-2013 08:40 PM
Quick Reply: Six Cylinder Exhaust Manifold Gaskets
