Entry level street/strip head
Old Jul 11, 2018 | 08:07 PM
weswes01's Avatar
weswes01
I had the pleasure of speaking with Bruce this morning and I have to say he’s just a really cool old school drag racer with enough stories to write a book. I think we all could relate to him in one way or another. He also told me how him and PMuller9 crossed paths. For those of you that don’t know PMuller9, he is an extremely sharp dude who is also very active in these forums. PMuller has been an absolute terrific educator to me. Almost every I know about these motors, I learned from him.
Bruce was very pleased with the results of the level 1 street/strip head. These flow numbers have exceeded all of our expectations with no cost to reliability. All your standard ford six parts will be a direct bolt on.
For those of you interested in this head please pm me your contact info. As this gets closer to production I will reach out to each of you. I will be working on a order form.
This is a a repost from ford-six.com
This is the First of many posts to follow, after our development team decided to separate the cylinder head flow development work into three distinct, mutually exclusive categories. 1) The entry level S/S or Street/Strip 2) the max -flow version. Both of these U-Flow offerings are patterned after the 1986 thru 1996 4.9L OEM Ford engine and are aftermarket sourced through EngineQuest the only supplier we are aware of. 3) will be the long awaited cross flow Aluminum casting “LS3 style” aftermarket NOT GM produced New castings. All development work on these 3 products from flow testing, fabrication, in-house machining, engine builds, to include Dyno testing, will be documented & chronicled via this Forum as time and resources permit.
Here are the finalized Street/Strip CFM flow numbers, expressed in thousands/inch Valve lift with manometer raw numbers corrected to 28” of Water.
.100-54; .200-100; .300-140; .400-176; .500-210; .600-220
None of us expected this much flow out of our type 1 head but after 4-months of thrashing on various combinations we are collectively very pleased to share this important outcome. Think of it this way; if you follow the basic Ford flow lab principals we had to adhere to [back in the day] they were a) maximize flow using the minimum cross sectional area b) maintain high velocity throughout the entire port length c) use the smallest diameter valve possible to avoid chamber shrouding.
We then added our own minimum program goal of 85% minimum ‘throat/pocket’ to valve seat inner diameter to the above principles for a personal roadmap of success. Importantly, we have exceeded this 85% requirement with a final throat ratio to seat on the intake side of 90%.
Soon you will have the finalized chamber volume for the type 1 head.
Soon you will have baseline cfm numbers for comparison to my Preparation H head we flowed earlier this year.
Soon you will have estimated HP and Torque numbers you can expect to achieve when you use this Type 1 assembled head on your engine package. ???Sound lofty, sure but doable using today’s available mathematical calculations.
LASTLY, our colleague PMuller9 will have a field day with this data and probably will amaze you with the accuracy of his projections vis-à-vis various engine configuration and outcomes possible with this much breathing ability. Bruce
Old Jul 12, 2018 | 04:38 PM
94Booger's Avatar
94Booger
Ok, so....so far these numbers match up with the GT-40 1994 Cobra head on the low end, and the GT-40x frp on the top end. Or at least in that ballpark. But it would benefit us non-tech savvy folks if you would include the factory flow numbers so we can see what the benefits of the hard work involved are. Just a suggestion.
Old Jul 13, 2018 | 10:53 AM
worldchampgramp2's Avatar
worldchampgramp2
EQ Cyl Hd Chamber shots
Thank you 94Booger for reminding me that We always MUST consider the adage ‘get back to the basics’. I will personally prepare an un-ported as cast 4.9L EFI Ford OEM head with stock Ford valves this weekend for CFM flow bench numbers. These numbers will be supplied by Monday along with generally accepted stock head flow numbers from other Ford enthusiasts I myself and PMuller9 have acquired from reliable sources.
Bruce aka Gramps and/or World Champ please don't call me Mr. Sizemore, YET !!
Here's a chamber shot of EQ head sans valve seats which is how we receive from our vendor.
Last edited by worldchampgramp2; Jul 13, 2018 at 10:55 AM. Reason: forgot to add promised pic
stupidcosmoline
Oct 19, 2011 02:48 PM
58AZF100
Mar 8, 2011 08:27 PM
F-250 restorer
Oct 24, 2010 03:30 PM
troposcatter
Oct 28, 2007 09:12 PM
bshackelford711
Flathead V8 & Flathead 6
Aug 29, 2005 08:05 PM
