Rumble at Startup When Turning
Old Feb 2, 2016 | 03:38 PM
michaelg10's Avatar
michaelg10
If the excursion has been sitting awhile (overnight, during the day etc.) I get a slight rumble at initial start up when I first get moving and turn the steering wheel. Once I get rolling it does not return. Doesn't matter if I am already moving before I turn the wheel or turn it right away.
Overall steering is tight with a new steering box. Doesn't really wander on me.
I read here that it could be a lack of friction modifier in the rear pumpkin. I confirmed with the VIN decoder at etis.ford.com that it has the 3.73 limited slip.
I recall that when I bought it a few months ago the PO said that he recently had the rear axle fluid changed, could they have forgotten to add it which is causing this? Should I add a bottle of modifier to it?
Old Feb 2, 2016 | 03:43 PM
michaelg10's Avatar
michaelg10
The axle code on the door jamb sticker is missing as well, like other 2000's.
Old Mar 13, 2016 | 12:33 PM
xcellent's Avatar
xcellent
My 2003 X does the same thing. Did the friction modifier fix your problem?
Thanks
OldJoeTucker
1997 - 2003 F150
Oct 11, 2012 08:02 AM
big job
Large Truck
Mar 12, 2010 06:42 AM
fballard
1997 - 2003 F150
Feb 14, 2005 02:29 PM
oz9609
Dec 24, 2004 09:35 PM
Stapler123
Sep 3, 2003 08:14 AM
