Sponsored by: Auxito
2003 F150 Front Differential Siezed
Old Oct 10, 2012 | 09:37 PM
OldJoeTucker's Avatar
OldJoeTucker
I replaced the differential shift fork a few years ago and was pleased with how easy the job was. Since that time when I put the truck into 4x4 everything works well until I try to turn, it feels like the front has a live axle in it. Are the differentials in these clutched or open? Im afraid I will eventually break an axle if I get this in too much of a bind. Would changing the fluid help it break loose or will I have to tear it down and rebuild to get it working right?
Old Oct 10, 2012 | 10:14 PM
Bluegrass 7's Avatar
Bluegrass 7
When your in 4x4 you can't turn the wheels sharp without wheel spraging.
If you could, 4x4 would be near useless with an open carrier and of limited value with a limited slip carier.
There is no limited slip option for the front axle.
Never run 4wd on a dry road surface.
It is for a surface that will allow one wheel to sprag 'a little' when turning
or using 4wd to pull straight, a load where traction is an issue or for traction help off road or in winter conditions.
You do understand that in a turn the outer wheel trys to turn at a faster rate than the inner one.
They can't because there locked togather and try to take over the steering as well..
Good luck.
Old Oct 11, 2012 | 08:02 AM
OldJoeTucker
I know not to run it on dry pavement, but wasnt sure about the live axle feel of it. I suppose I wont worry about it anymore if that is the way its supposed to be.
Thanks
OJT
BillRes2
Sep 11, 2018 01:25 PM
d_gant
2004 - 2008 F150
Apr 25, 2016 08:24 PM
ARK Ranger
2009 - 2014 F150
29
Nov 21, 2012 05:17 AM
KC8QVO
Jul 26, 2010 09:57 PM
Feb 21, 2007 01:43 PM
