Stalling problems
Old Jun 24, 2009 | 06:28 AM
Old Time Ford's Avatar
Old Time Ford
Stalling problems
I have a 92 F250 with a 351w the problem is it will run for 10 to 15 minutes and then stall at that point we lose communication with the computer.If we wait a few minutes it will start and run but stall again when it stalls it will burn real rich then stall.It will run about the same amount of time each time it runs.
Keith
Old Jun 24, 2009 | 09:15 AM
17fordguy's Avatar
17fordguy
i would start withe the computer. sound as though it runs fine until it warms up then after it warms up somthing is going wrong with the comp and causing it to shut down.
Old Jun 24, 2009 | 09:33 AM
subford's Avatar
subford
What do you mean by "lose communication with the computer"?
Have you checked for spark when it shuts down?
I have not heard of a Computer going bad this way I would think more on the lines of a bad MAP sensor if you still have spark when it shuts down.
The MAP sensor may also have the vacuum hose off or a leak in it.
Old Jun 24, 2009 | 10:05 AM
Old Time Ford
When we have the scanner hooked to it .it tells us that it has lost comunication.
Old Jun 24, 2009 | 10:34 AM
subford's Avatar
subford
Try grounding the STI wire without that scanner and see it the PCM will do the KOEO self-test by flashing the MIL. If it will not do the Self-test then you may have a bad computer.
Old Jun 25, 2009 | 05:44 AM
Old Time Ford
Thanks for the help we are going to replace the computer.I"ll let you all know what happenes.
Keith
gallgood
6.2L V8
Jun 7, 2011 07:23 AM
Ohio Ford Farm
Jan 24, 2009 08:47 AM
norg1
Bronco II
Aug 13, 2007 04:57 PM
Rich Wood
May 12, 2007 04:24 PM
Ranger88
4 Cylinder Engines
Dec 1, 2005 01:30 PM
