'53 wheel location
Old Feb 6, 2016 | 11:50 AM
Nicholas+'s Avatar
Nicholas+
Why don't you snap a few pics of the crossmember, how its mounted and how your engine is attached. Hard for anyone to answer with out a visual.
Old Feb 6, 2016 | 06:42 PM
CharlieLed's Avatar
CharlieLed
Here is the same IFS crossmember installed on my 56...I would not recommend un-installing the crossmember just to move it an inch. Not only will it be an issue structurally (lots of heat in that area to embrittle the metal) but the notches for the tie rods would also need to be moved. Not a good idea. My recommendation to the OP is to check the wheelbase and to check the square of the frame...if all is good then build the chassis and get on with other pressing issues.
Old Feb 16, 2016 | 07:19 PM
Marten's Avatar
Marten
So I had the truck out for some sun shine yesterday afternoon. I have flipped the rear cab mounts over and reset the cab. It looks like the wheels are in the correct spot after all. So now I can move forward. Thanks for all the advise guys.
Old Feb 16, 2016 | 07:32 PM
avf100's Avatar
avf100
Looks much better !! I bet you let out a big ole sigh of relief when you sorted out the problem.
Old Feb 16, 2016 | 07:41 PM
Nicholas+'s Avatar
Nicholas+
That looks better!
Lwlandy
Mar 24, 2014 12:53 PM
NVRAGN
Jun 26, 2009 11:46 AM
lowtrkn2k
29
Mar 4, 2009 06:54 AM
houghda
Apr 10, 2007 07:49 PM
R H
Jan 14, 2007 05:24 PM
