Auto trans shifting
Old Jan 30, 2016 | 07:50 PM
Bird-Dog 250's Avatar
Bird-Dog 250
Auto trans shifting
My auto trans acts up from time to time. It down shifts at the wrong time, won't go into overdrive unless I speed up and let off. It's been fine for weeks and then it will act up. I'm thinking its electronic? My tester is at home, we've been away for 3 months, so I'll check for codes asap. Your thoughts?
Old Jan 30, 2016 | 08:11 PM
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
My thoughts are that you need the codes.
Old Jan 31, 2016 | 04:09 AM
Bird-Dog 250
Will be home tomorow....
Old Feb 2, 2016 | 12:06 PM
Bird-Dog 250
My scanner is an OB2! Won't work on a 97 7.3. What are you using to scan?
I'll post another thread on this so it gets looked at but the truck seemed to skip under load. The scanner for the diesel should pick up on this too
Old Feb 2, 2016 | 12:54 PM
chrismd188's Avatar
chrismd188
sounds to me like it could possibly be the neutral safety switch (mlps)
on the drivers side of the trans
Old Feb 2, 2016 | 02:23 PM
Bird-Dog 250
Don't see how...neutral safety is for starting in park or neutral and not allowing it to start in a gear.
Old Feb 2, 2016 | 03:34 PM
Mark Kovalsky
That sounds unlikely to me, but if we had the codes I could make a really good guess.
Old Feb 2, 2016 | 03:42 PM
chrismd188's Avatar
chrismd188
the neutal safety switch does more than that
I was having a problem with my overdrive not working and the light would flash,it would slip all forward gears randomly.
I checked and replaced the mlps and haven't had a problem since.
It does a lot more than an old neutral safety switch.
Old Feb 2, 2016 | 04:18 PM
Bird-Dog 250
How do I get the codes? I have a scanner but for OB2 only. I thought Auto Zone could scan for me but was told here they they couldn't do it. What do I need for a scanner where can I go. It might also discover why the truck vibrates with a load or acceleration. Taking my foot out of it will stop it from doing so.
Old Feb 2, 2016 | 05:30 PM
Lead Head's Avatar
Lead Head
You probably have a bad/weak injector.
Most consumer scan tools will not work on a 1997 7.3 PSD, despite it having the OBD-2 port. You'll either need to get a specialized scan tool, or bring it to a dealer.
Old Feb 2, 2016 | 07:53 PM
Bird-Dog 250
I was afraid of that! I wonder if they know what to do for an 18 year old truck?! or if they can even still plug into an old truck and get the codes.
Old Feb 2, 2016 | 09:08 PM
Lead Head's Avatar
Lead Head
Yes, they will know how to diagnose a PowerStroke.
Old Feb 2, 2016 | 09:16 PM
Bird-Dog 250
Ok then...I'll go to the dealer and see what I can find out. I'll be back
blk88notch
May 25, 2021 09:53 PM
brian.b
Feb 23, 2019 02:42 PM
1997fordf350
Feb 4, 2014 09:01 PM
panelguy
1997 - 2003 F150
Jan 4, 2013 08:32 PM
jethro
Sep 12, 2001 11:51 PM
