37" x 16.5 humvee tires fit on my 1976 highboy stock????
At one point I had these on with no lift. I did have the front fenders modified a little but I don't know of that was actually needed. I had my 40" groundhawgs on with no lift which really are aliens the same size just much wider. I think you will be fine. I'll see if I can find a picture or 2 from back then.
All I did was notch the fenders to make the bend then added wheel well liners to make it less noticeable. Most people never notice. These are mounted on stock wheels and are a real pain to get blown up. Narrow rims like theses are definitely better. We tried many tricks but it came down to using tire mounting compound. If you try a 9 3/4" rim all I have to say is good luck.
tastyklair
15
01-09-2005 03:25 PM
