Fuel guage problems
Old Jan 28, 2016 | 12:42 AM
texasblue55's Avatar
texasblue55
Fuel guage problems
I have a 68 F250 with dual fuel tanks. When I fill up the main tank the fuel gage registers 3/4 full. It runs out of fuel when the gage is at 1/4 tank.
When I switch to the auxiliary tank, the fuel gage registers empty and that is with a full tank.
Any suggestions to solving this problem
Any advice is much appreciated.
Randy
Old Jan 28, 2016 | 01:28 AM
RichS2659's Avatar
RichS2659
Your fuel sending unit floats are bad. They are full of fuel. You will hear fuel sloshing in them. Replace them.
Old Jan 28, 2016 | 09:42 AM
Freightrain's Avatar
Freightrain
The tank behind the seat is an easy fix. Remove sender and bend the arm down a touch. That will make it read FULL when full and Empty when empty. Might have to adjust it a few times. Do it when the tank is full that way you can instantly check.
The aux tank? Either the float is sunk or the sender is bad/wire broken. Go back to the sender and ground it. If the gauge pegs full it is the sending unit. If nothing happens then the wire is broken somewhere. Try testing the switch.
Old Jan 28, 2016 | 10:45 AM
texasblue55
Fuel Sender
How do I ground it.
Old Jan 28, 2016 | 10:51 AM
Freightrain
Take the wire off the sender and touch it to the body/frame.
Truck Guy99
Nov 28, 2013 10:39 PM
blacken77
Oct 17, 2012 02:33 PM
Jmackenroth
Jul 5, 2005 05:41 PM
boogity24
Jul 21, 2004 05:58 PM
ODB2
May 24, 2004 10:28 PM
