Fuel tank problem
Old Nov 27, 2013 | 10:30 PM
Truck Guy99's Avatar
Truck Guy99
Fuel tank problem
I am having problems with my 1988 F350's fuel tanks. I was told by the PO that the front tank doesn't work and is full of old nasty fuel. He doesn't know what's wrong, he just knows it doesn't work. I plan to drop it and replace the old tank, but how do I troubleshoot it? Is there a way to test the switch and sending unit?
The rear tank is fine functionally, but the gauge either occasionally works or always reads full. Is this a grounding issue?
Old Nov 28, 2013 | 07:43 AM
subford's Avatar
subford
On an 88 it would be a short to ground to make the fuel gauge go to full.
An open or lack of ground would make the fuel gauge read empty.
You may also have the wrong year sender in the tank.
You need to replace the tank, sender and pump (one item), fuel filter and maybe clean the selector valve.
Old Nov 28, 2013 | 10:54 AM
90'F150's Avatar
90'F150
I gotta couple problems with the gage on my truck and was told it could be the ground but I can't seem to find it any idea where the grounds are for the sending unit?
Old Nov 28, 2013 | 11:04 AM
subford's Avatar
subford
Sure it is located on the LH (drivers side) radiator support.
Old Nov 28, 2013 | 10:39 PM
90'F150's Avatar
90'F150
Lol wow I've been looking by the tank thanks so much gonna get on that tomorrow.
CClark56
Oct 11, 2010 11:55 AM
jrr31977
Mar 18, 2009 06:34 PM
White EddieB
Oct 16, 2008 04:37 PM
Nighteyez
Dec 29, 2006 03:19 PM
DavidHenshaw
Jul 11, 2006 06:47 AM
