56 Wiper blades
Old Jan 27, 2016 | 04:11 PM
dadgonebroke's Avatar
dadgonebroke
56 Wiper blades
Ok- I'm sure this has been beat to death but I can't seem to find any threads that pertain. Time for wiper blades for the 56 F100. I go the the internet and I don't see anything like what I have. In fact, It looks like what I have is all one piece- the arm and blade all one piece. I went through this last time and the blades I got were different that what I had. This is getting old. Can you straighten me out for what I need?
Old Jan 27, 2016 | 05:26 PM
leonharu's Avatar
leonharu
Can you just change the inserts?If so,go to Advance Auto and they can possibly order some to fit.I think they have to special order them from Anco.
Old Jan 28, 2016 | 01:04 PM
dadgonebroke
56 wiper blades
Come on- someone else has to have run into this issue before!
Old Jan 28, 2016 | 01:20 PM
arctic y block's Avatar
arctic y block
Can we see the blades your using?
Old Jan 28, 2016 | 01:29 PM
ALBUQ F-1's Avatar
ALBUQ F-1
The end is removeable from your arm. Look underneath, there is a leaf-spring like piece you have to release so it comes off. I think I see the end of it in your picture.
Are 56 wipers the same as 53-55? Check this thread: https://www.ford-trucks.com/forums/1...iper-arms.html
Old Jan 28, 2016 | 06:48 PM
56panelford's Avatar
56panelford
As far as I know the blades are the same but the left side of the 56 arm is different due to the location it mounts. The blades are removable like Ross says. I bought mine through Midfifty with an extra pair of blades..
Old Jan 28, 2016 | 08:03 PM
gerrymoe's Avatar
gerrymoe
Search Results - Mid Fifty F-100 Parts
Mid Fifty has just the rubber refills for 8.50 a pair. The blade replacements are currently on a four week back-order, They cost 15.00 apc.
Take your old rubber blade out and take it to Napa they have them
Old Jan 28, 2016 | 09:08 PM
56panelford
That's good to know too Gerry, thanks for the heads up on that, just hope the Napa store's up here are half as good as the ones down there..
Old Jan 29, 2016 | 03:55 PM
dadgonebroke
Yes there is- but it's riveted.
Old Jan 29, 2016 | 04:08 PM
dadgonebroke
blades
Amazon popped up and shows $12.82 delivered for a pair.
Old Jan 30, 2016 | 03:04 PM
dadgonebroke
Found a pair of inserts on Amazon for $9.43.
Old Feb 5, 2016 | 09:12 AM
dadgonebroke
done!
Inserts solved the problem. I'd forgotten what a pain the butt they are to install! lol I tried the local parts stores but no one had anything close.
Old Feb 5, 2016 | 06:53 PM
Rimrock F1's Avatar
Rimrock F1
Actually that is not a rivet. I know you have the problem solved but since I have the same setup and removed them today I thought I would tell you how. Hold the bracket on the top of the wiper in one hand. While pressing the arm down toward the rubber part of the blade (right where it enters the bracket you have in your other hand) pull the two pieces apart. Once you learn the trick it takes about 5 seconds.
leonharu
17
May 12, 2019 07:03 PM
Truxx1956
Jun 15, 2011 08:03 AM
johnboggs21
17
Jun 6, 2010 02:21 PM
53choptop
Nov 15, 2003 08:45 PM
spacecoast
Oct 17, 2002 05:44 PM
