Cooling Fan Problem
Old Jan 27, 2016 | 12:26 PM
jl226's Avatar
jl226
Cooling Fan Problem
I currently have a 2003 F-250 6.0 with 112,000 miles on it. While traveling interstate speeds (70+) and the I can hear the cooling fan rev up and down every 110-15 seconds. Is this normal?
Also when it spins up, it sounds normal then make a high pitched squealing noise. Thoughts?
I am also needing to rebuild the fuel bowl. I noticed DieselOrings offers rebuilds for the 7.3 but not the 6.0. Will these fit or any suggestions on parts?
Thanks
Old Jan 27, 2016 | 01:06 PM
texastech_diesel's Avatar
texastech_diesel
Token Redneck
Blue spring kit should come with all the o-rings you need on the secondary filter housing; you need the spring if you don't already have it:
Ford Fuel Pressure Regulator Blue Spring Kit - Riffraff Diesel Performance
Fan clutch sounds like its locking up incorrectly. Do you have an EGR delete? Any any gauges to watch the duty cycle on the fan clutch and fan speed?
https://www.ford-trucks.com/forums/1...eral-info.html
Old Jan 27, 2016 | 01:12 PM
amdriven2liv's Avatar
amdriven2liv
I'm hitting easy street
What are your EOT and ECT temps?
Old Jan 27, 2016 | 01:27 PM
jl226's Avatar
jl226
The fan clutch was my guess, but I'm no mechanic. The truck has not had an EGR delete and I have only had to replace the water pump on the truck. I do not have any gauges to check the fan, but I can get the download for Torque Pro on my tablet and check it there.
I noticed a slight diesel smell under the hood and found a small amount on the top of the engine, so it appears I need to rebuild the fuel bowl.
Thanks for the help.
Old Jan 27, 2016 | 02:17 PM
jl226's Avatar
jl226
I'll have to get the gauges set up, I'll update once that's done.
Old Jan 27, 2016 | 02:27 PM
FiveOJester's Avatar
FiveOJester
You could also be running hot due to plugged radiator, failing water pump, etc. Fan hits full speed when the ECT is around 218.
Gauges will tell you!
Old Jan 27, 2016 | 03:25 PM
BPofMD's Avatar
BPofMD
Veteran: Navy
He also needs to check the wiring up near the water pump/fan.
Old Jan 27, 2016 | 03:54 PM
jmaskew's Avatar
jmaskew
Checkout this article. I used this page when I had issues with the fan clutch.
Ford F350 SuperDuty Pickup 4x4: 05 F350, 6.0 GETTING A PO528
shredder
Dec 6, 2015 04:29 PM
dr103
Feb 9, 2012 06:15 PM
Shaner911
Mar 11, 2009 05:11 PM
E350turbo
Jun 24, 2004 05:52 AM
rsrxc700
Aug 6, 2003 09:21 PM
