Upper fuel return line quick connect size???
Old Jan 27, 2016 | 10:25 AM
Nightwolf881030's Avatar
Nightwolf881030
can someone please tell me what size the quick connect at the drivers side fender-well is for the fuel return line?????????????????
I am trying to figure out what size the quick connect fitting is at the fender-well so i can order the proper male quick connect to -6an or -8an fitting.
I know at the HFCM feed line is 3/8 QC and return line is 5/16QC but at the fender-well QC points they both look the same size.
Thanks in advance.
Old Jan 27, 2016 | 07:01 PM
Nightwolf881030
Has anyone even utilized these quick connect fittings?
Old Jan 28, 2016 | 02:50 AM
Yahiko's Avatar
Yahiko
Look at metric sizing.
What brand of adaptor are you looking to use?
If you have not looked here yet >>> Aeromotive OEM and Specialty Adapters | Aeromotive
You may want to give them a try. Let them know what your trying
to do and have them find the right item for you.
Sean
6.0L Tech Folder
Old Jan 28, 2016 | 08:07 AM
Nightwolf881030
Yahiko
Thanks for the reply.
The Aeromotive OEM and Specialty Adapters is exactly what I've been looking at however I'm not particular on the brand of adapter I use so long as it fits and doesn't leak.
I am positive jegs has what I'm looking for as they have just about every size however they could not tell me what size it is that I need.
I have even called the dealership and they cant tell me the size either.
so unless someone chimes in today with an answer I guess Ill just order 2 or 3 different sizes and see wich one fits.
dyoungen
Jul 11, 2017 08:20 AM
thendrix
Mar 24, 2017 02:22 PM
KDAVID1
Oct 12, 2015 10:15 AM
johnarahill
Nov 21, 2011 01:38 PM
maxt
1997 - 2003 F150
Apr 17, 2008 10:11 AM
