Vibralok connector size?
Old Nov 21, 2011 | 12:33 PM
johnarahill's Avatar
johnarahill
Does anyone know what size the vibralok connectors on the top of the fuel tank are and if I can get them from a typical parts store? I destroyed mine today.
Old Nov 21, 2011 | 12:56 PM
Shake-N-Bake's Avatar
Shake-N-Bake
I do not know the size but you can get them from Grainger (if there is one in your area).
Here is a sheet that might help you determine the size on your own.
File Type: pdf
Old Nov 21, 2011 | 01:10 PM
PaysonPSD's Avatar
PaysonPSD
There are no vibra-lok fittings on top of tank for the supply line or return line unless they were modified.
If you are talking about the quick-connect fttings like this
just replace them with a suitable length and diameter diesel rated rubber fuel line and double clamp them.
That is part of the "In-tank Mods". See this LINK.
Old Nov 21, 2011 | 01:26 PM
ChunderDownUnder's Avatar
ChunderDownUnder
X2 Get rid of em and use hose and clamps. They suck air into the lines.
Old Nov 21, 2011 | 01:38 PM
Shake-N-Bake
Oops, I thought the OP was asking for the parker sleeves at the fuel filter bowl. I must not have read the post correctly. My mistake.
J33pinmiller
Jun 13, 2019 12:28 PM
paddler
Feb 1, 2017 07:59 PM
Dorsai
May 22, 2012 09:43 AM
texasjack
Feb 12, 2009 01:51 PM
