Is this.......
Old Jan 26, 2016 | 03:28 PM
silverbullet6oh's Avatar
silverbullet6oh
Is this.......
Is this the port for a EGT probe/thermocoupler?
I was messing around under truck, and found this. There is only one, and its on the drivers side.
Old Jan 26, 2016 | 03:37 PM
WatsonR's Avatar
WatsonR
sure looks like one to me
Old Jan 26, 2016 | 03:55 PM
Mcrafty1's Avatar
Mcrafty1
If not it's missing a good chance to be one......I guess what you'd need to know is the thread size of that port and the probe/thread size of the EGT sensor you were going to try and put there.
Old Jan 26, 2016 | 04:11 PM
BPofMD's Avatar
BPofMD
Veteran: Navy
I'd be spraying a ton of PB Blaster before I tried turning that bolt!!!! But - I agree, it sure looks like someone had a probe in there at one time!
Old Jan 26, 2016 | 04:43 PM
silverbullet6oh
Thanks guys, for confirming my suspicion.
I wouldn't take it out, I would just remove the cap on it and find a sensor that would fit it.
Old Jan 26, 2016 | 07:32 PM
BPofMD's Avatar
BPofMD
Veteran: Navy
Mine is threaded directly into the manifold..... I thought that the whole bolt would have to be removed......
Old Jan 27, 2016 | 11:20 PM
FICMrepair.com's Avatar
FICMrepair.com
Former Vendor
I've had unbelievable luck with a product called 'Kroil' for rusty bolts, FWIW. It's between that and a 50/50 mix of ATF/Acetone. The results are truly hard to believe.
Good luck!
bigspeedy626
May 18, 2018 10:09 PM
FMJ.
26
Jul 31, 2017 09:11 PM
Rusty Axlerod
Nov 19, 2012 10:19 PM
BPofMD
Maryland Chapter
Jan 7, 2010 08:02 AM
glruff
Nebraska Chapter
381
May 21, 2008 03:17 PM
