Haven't touched the gears. So I assume they are stock.
Have a look at the door sticker, under the axle heading will be a code that will indicate the gear ratio and if it's a limited slip or open differential. The V-10 EXs came with the 3.73 as the standard gear set and the 4.30 was the optional performance/towing ratio.
Thanks very much for the info. I'll look tomorrow and let you know what I find.
I'll probably just take a pic of it and post it.
I'm pretty sure it's limited slip because I spun both tires the other day.
