Column shifter. The missing link?
Old Jan 26, 2016 | 06:27 AM
Color sarge's Avatar
Color sarge
I am using the original column shift linkage to shift the FMX trans in my 1952 F100. I used the 3-4 shift arm hooked to a cable. This set up works, but there is a couple inches of play in the shifter. Play is in column itself, not in cable set up. Does anyone know where I can look to eliminate this play? Thanks
Old Jan 26, 2016 | 09:16 AM
ALBUQ F-1's Avatar
ALBUQ F-1
There's probably only one place to look. The shifter tube moves the 2-3 lever thru a pin in the tube, that slides into a slot in the lever. The pin could be sloppy in the tube, or the pin fit in the slot could be sloppy, or both. See picture below.
Old Jan 26, 2016 | 10:38 AM
Color sarge
Thanks, I'll check that. BTW meant 2-3 shift. Not a four speed.
Old Jan 26, 2016 | 11:05 AM
ALBUQ F-1's Avatar
ALBUQ F-1
If that's where it's sloppy, you could replace the pin with a bolt, and just lock it in position.
Old Feb 1, 2016 | 07:29 PM
Color sarge
OK. Disassembled column shifter. Removed 1st and reverse shift arm completely. Removed pin for 2-3 shift arm and replaced with bolt and nut. Then tack welded that arm solid to shifter shaft. Play now gone. Thanks
Old Feb 1, 2016 | 07:53 PM
Lola's Panel's Avatar
Lola's Panel
Hi, I was wondering if you could snap some more pics of your linkage. I was hoping to do the same. thanks
Old Feb 2, 2016 | 07:32 AM
Flat Ernie's Avatar
Flat Ernie
I need to do this too on my AOD shifted by my column 2-3 lever....but I just deal with the nearly 3" of play!!
Old Feb 2, 2016 | 07:49 PM
Color sarge
Hard to believe a little play in that pin translates to nearly 3 inches at shifter. I simply replaced the pin with a 5/16 carriage bolt after grinding the square part round. Also had to grind flat part of bolt head for clearance. I welded shift arm to shaft also, but, don't think this step absolutely necessary . Performed this modification without removing steering column. Just removed shift assembly. No one makes floor shift for FMX and wanted column sift for more leg room and originality. Will try to post some pics tomorrow night.
Old Feb 3, 2016 | 06:43 PM
Flat Ernie's Avatar
Flat Ernie
No idea what all is worn in mine...works fine though!
Old Feb 3, 2016 | 07:11 PM
Color sarge
Tried to attach two photos. Hope this works. One of parts I discarded and one of finished modification. Hope this helps.
Old Feb 3, 2016 | 07:22 PM
Color sarge
Trying again
1972Herbie
Dec 2, 2014 09:08 AM
Lonzo
May 6, 2011 02:06 PM
nathant
May 22, 2010 09:11 AM
wisconsin
Dec 11, 2007 02:23 PM
laptopgeek
Aug 30, 2002 09:59 PM
