Quick lift question...
Old Jan 27, 2016 | 11:27 AM
  #31
2wdDezlX's Avatar
2wdDezlX
Originally Posted by Apocalypse
I'm running 305/16s BTW
305/75r16?
Old Jan 28, 2016 | 10:14 AM
  #32
pirate4x4_camo's Avatar
pirate4x4_camo
FTE Remembers
I have ATS springs. Whatever his highest kit is I bought. It's the same as Twitchys kit.
I was hoping somebody was going to chime in with the measurements, twitchy said x/c so what ever that translates to ?
A few possibilities.
If you are at 4 and add 2" then you may need :
*a new track bar mount and possibly a adjustable track bar.
* longer or relocated brake lines
* bump stop spacer
* castor bushings or wedges ( depends on the springs and shackle used )
* tapered block in the rear
* driveshaft lengthened
* shocks
I know you only asked about steering components but I listed everything for anybody else considering doing the same thing who may be unaware of the "other" stuff.
Old Jan 28, 2016 | 10:24 AM
  #33
Twitchyleprechaun's Avatar
Twitchyleprechaun
I don't have a kit. I simply have X/modded C springs.
Old Jan 28, 2016 | 10:44 AM
  #34
pirate4x4_camo
FTE Remembers
Originally Posted by Bently_Coop
What springs do you have?
Originally Posted by Twitchyleprechaun
X/Modded C
I would still like to know however, would the shackle in the front and larger block in the back work without any other mods? Is there anything wrong with that?
twitch, I only quoted you since x/c is so far the best info we have on his current mods, it is not possible to give him a more specific answer until we have more specific info.
so I listed some of the other things that will need to be considered since I do not know what measurements x/c translates into nor do I know what size block or shackle he is considering.
Old Jan 28, 2016 | 11:02 AM
  #35
Apocalypse's Avatar
Apocalypse
* bump stop spacer
* shocks
This is exactly what I was looking for! Half of that stuff doesn't apply to me but that's the list I wanted to see thanks for posting that! I'm totally out on ever doing that then, I'd rather just buy a lift kit and sell my springs then do all of that.
Old Jan 28, 2016 | 12:33 PM
  #36
pirate4x4_camo
FTE Remembers
I'm am totally confused.
But if the list was a help then you are welcome.
Old Jan 28, 2016 | 05:11 PM
  #37
Bently_Coop's Avatar
Bently_Coop
I think he figured if could bolt some taller blocks in the rear probably for from stock to a F350 and shackles up front without changing anything else. Everything you just mentioned sounds like cha ching and not worth the effort since everything current is fairly new.
Old Jan 28, 2016 | 05:24 PM
  #38
pirate4x4_camo
FTE Remembers
Ah got it. Thanks
Old Jan 28, 2016 | 09:06 PM
  #39
Stewart_H's Avatar
Stewart_H
Ah got it. Thanks
@Bently_Coop, the Apoc whisperer.
Stewart
Old Jan 28, 2016 | 10:18 PM
  #40
Bently_Coop
Well thanks @Stewart_H.
Only trying to interpret with what I see.
Old Jan 28, 2016 | 10:28 PM
  #41
Skip1970's Avatar
Skip1970
them duke boys didnt use no stinking blocks, you just cant jump it with blocks cooter said!
Old Jan 28, 2016 | 11:36 PM
  #42
Apocalypse's Avatar
Apocalypse
Exactly I would have sent reps but I still need to spread them around
Firewhoop3
1997 - 2003 F150
Dec 3, 2011 07:50 PM
crowes99
Aug 24, 2010 10:12 PM
krol
Offroad & 4x4
Jul 5, 2005 12:03 PM
38inchf250
Dec 11, 2003 08:02 PM
