Quick lift question...
Old Jan 26, 2016 | 09:34 PM
pirate4x4_camo's Avatar
pirate4x4_camo
FTE Remembers
Originally Posted by Skip1970
i dont understand why these excursions have front track barswith leaf springs, almost all leaf fords ive owned didnt have trac bars. im gonna take mine off, the coil sprung fords ive had needed tracbars and had them.
Am I reading that correctly , you don't understand why your truck has a certain suspension / steering component so you are just going to remove it ?
So I guess that begs the question, if you are removing the track bar what design changes are you going to make to the suspension and steering to contend with the bump steer ?
Old Jan 26, 2016 | 11:11 PM
Skip1970's Avatar
Skip1970
what im saying is why does the excursion have a tracbar when all the 70s and 80s solid axle leaf sprung fords not have them that i have owned? what makes it needed on the excursions?
Old Jan 26, 2016 | 11:41 PM
pirate4x4_camo
FTE Remembers
it is basically a bandaid to help antiquated technology achieve something resembling acceptable handeling.
A simplified explanation is that your suspension travels in a arc, your steering also follows an arc, the trac bar keeps the alignment of the suspension and the steering on a close enough plane during their movement so that it does not change the steering angle as the suspension cycles. When your suspension travel changes the steering angle it is called bump steer.. Sorta self defining. Hit a bump and the steering angle changes.
This is why when a lift is installed a new track bar mount is used that keeps the drag link and track bar parallel.
Old Jan 26, 2016 | 11:44 PM
Skip1970's Avatar
Skip1970
i know what a track bar is, and a tracbar doesnt prevent bumpsteer.
Old Jan 26, 2016 | 11:57 PM
pirate4x4_camo
FTE Remembers
Please share.
Old Jan 27, 2016 | 12:03 AM
Skip1970's Avatar
Skip1970
bumpsteer is when your suspension compresses and causes the draglink from your steering arm to be pushed in turn causing the spindle to rotate on the ball join or king pin making your vehicle turn with the suspension cycle.
i honestly think trac bars on a non lifted leaf spung vehicle are someones feel good moves at safety, when infact i think they may cause a vehicle to roll over easier in a high speed turn due to binding of the suspension. but thats just a wild theory.
Old Jan 27, 2016 | 12:10 AM
pirate4x4_camo
FTE Remembers
You are correct on the bump steer, now keep working that concept, What causes "the drag link to push in and rotate the spindle " ?
Old Jan 27, 2016 | 02:25 AM
Apocalypse's Avatar
Apocalypse
Originally Posted by USCG_PA
^^^^ What he said ^^^^
If you really want the no step look, just dave up and get the retractable ones the Michael is running. I know they are expensive, but it would be a very nice upgrade that once done will always offer both the looks and the functionality.
I think this is exactly what I'm going to do. I want the no step look more than anything but with those steps Wendy could get in easier because their height can be adjusted! That is a perfect 8 month purchase item!
I would still like to know however, would the shackle in the front and larger block in the back work without any other mods? Is there anything wrong with that?
Old Jan 27, 2016 | 02:32 AM
Skip1970's Avatar
Skip1970
suspension compression or extension
Old Jan 27, 2016 | 05:01 AM
Bently_Coop's Avatar
Bently_Coop
Do you have a current picture of ride height and measurements? What size are the current tires?
I can't say about the rear or front if anything would be needed.
Old Jan 27, 2016 | 05:20 AM
2wdDezlX's Avatar
2wdDezlX
I would think that you would "need" or want larger tires (like all of us would) after that and it wouldn't be just a small lift. I think the amp running boards is your best option to get the look you want.
Old Jan 27, 2016 | 09:58 AM
pirate4x4_camo
FTE Remembers
Both,
No sense in explaining one without the other since the suspension has to go up and down.
Old Jan 27, 2016 | 10:09 AM
  #28
holeshotwalt's Avatar
holeshotwalt
Let us know how that turns out- I'm pretty sure Ford wouldn't put ANYTHING on these trucks that wasn't needed (except for the weight thingy that hangs down under the frame).
Hell, mine didn't come from the factory with a rear sway bar; and I KNOW it needs that to be driven safely...
Old Jan 27, 2016 | 10:10 AM
  #29
pirate4x4_camo
FTE Remembers
Retractable running boards from AMP or Bestop are not adjustable. I have seen longer arms made for them so they extent further but they still only offer 2 positions.... Open and closed
Shackle mods = depends on how much castor you currently have and how long of shackle you use. You will need an alignment afterwards and then whatever mod is required to get the castor back in spec.
Old Jan 27, 2016 | 10:48 AM
  #30
Apocalypse's Avatar
Apocalypse
I'm running 305/16s BTW
