Proper engine ground '77 400
Old Jan 25, 2016 | 06:22 PM
mbeards's Avatar
mbeards
Can anyone explain or maybe post a picture of how to properly install the electrical ground for the 400 engine?
I'm working through a number of various electrical issues and I want to be able to confirm that I have this right. The only braided strap I see is bolted near the top of the back of the engine bay/the firewall on the passenger side and is attached to the hood.
I'm also looking for a photo/clear description of the proper way to ground the steering column. It's a 4x4 auto transmission. After rebuilding the top of the streering column and installing a new turn signal switch and wheel, the horn only works if I clip a jumper from the column to the engine bay somewhere. I'd like to get this permanently installed the right way.
Old Jan 25, 2016 | 06:25 PM
ubereal2's Avatar
ubereal2
When I added more grounds to my 79, I used heavy battery cable with an open eyelet at each end. One to the engine block, the other end to the frame. I did also wire brush both places to help with get a good connection.
Unk Bob
Old Jan 25, 2016 | 07:12 PM
77&79F250's Avatar
77&79F250
Moderator & parts slinger
From the back side (r/h as looking in) of the intake goes to the fire wall.
Hood to firewall is separate.
And this sweet idea.
Horn is a jumper across the rag joint.
Old Jan 25, 2016 | 07:46 PM
HIO Silver's Avatar
HIO Silver
Redundant grounds are a good thing...
The firewall to engine is really important. I forgot to reconnect it after rearranging some vacuum and electrical harnesses and the electric fuel pump would cycle when I turned on the headlights!
In addition to the stock grounds, these are general Recommendations:
Cab to frame
Bed to frame
Core support to frame
Hood to cab
Inner fenders to frame
Battery to frame
Old Jan 26, 2016 | 12:29 AM
hivoltj's Avatar
hivoltj
Stock had firewall to back of the intake and negative battery cable to passenger side of the block, below and behind the alternator
df85732
23
Jun 15, 2018 10:27 PM
kindorotten
24
Aug 21, 2016 10:18 AM
46fordgal
1947 and Older Ford Trucks
Mar 13, 2015 05:22 AM
664x4drvr
Jul 11, 2013 05:10 AM
hamz52
May 12, 2008 01:15 PM
