Sponsored by: Real Truck
Steering issue
Old Jan 24, 2016 | 12:30 PM
Paul Anspach's Avatar
Paul Anspach
Steering issue
Just got my F350, 2003. The steering wheel is at 10 and 4 when going straight down the road with play between 10/4 and 9/3. I've checked everything, from the pitman down the drag link, tie rod ends and ball joints. Everything is tight. But when I reach through the wheel well to the steering column i can turn it with my hand making a click at the stops either way.
Am I staring down a new steering box??
Old Jan 24, 2016 | 02:43 PM
redford's Avatar
redford
FTE Leadership Emeritus
I would at least check the gear box for play.
Old Jan 24, 2016 | 02:50 PM
Paul Anspach
What should I do, drop the drag link and pull/push the pitman arm?
Old Jan 24, 2016 | 05:06 PM
redford's Avatar
redford
Start with just looking at the box while someone turns the wheel, looking for obvious play.
Old Jan 24, 2016 | 05:40 PM
Paul Anspach
There's play - I can turn the steering column back and forth from the wheel well. I have no idea if this is normal for a ford.
Old Jan 25, 2016 | 08:21 AM
Paul Anspach
anyone, any thoughts? I have no idea if this is a steering box issue, I would expect the steering wheel to be tight. I'm a jeeper and we don't typically see steering gears as an issue - I'm seeing a lot of questions about this on the ol' 'inner-web like it's common for gearboxes to go at around 100k miles.
before I go to drop the scratch on a new one, just wanted to poll the audience since this forum has so much good info on it.
thanks!
Old Jan 25, 2016 | 08:40 AM
nards444's Avatar
nards444
Just went through steering issues. What fixed slop on mine was a steering stabilizer. It will look like a shock up on the front end going horizontal left to right.
Easy check is to take one end off and push it in, if it doesn't retract its bad and replaced. Theyre like 40 bucks at autozone.
Old Jan 25, 2016 | 08:42 AM
Paul Anspach
it's definitely not the steering stabilizer, my wheel play is above the gear box, everything from the pitman down is solid.
Old Jan 25, 2016 | 08:51 AM
ZooDad's Avatar
ZooDad
Retired guy fixn stuff
With the truck off, have someone turn the wheel just enough to start to move the tires. While you look at the steering shaft where the pitman arm is. Look for vertical movement (in-out/up-down). If present you can take up some lash by adjusting the preload on the top of the box. Go in small increments.
I ended up replacing mine with a RedHead box.
Hope this helps.
Keith
candicane91
Jun 16, 2015 08:59 PM
GR$$N$
Sep 15, 2011 02:56 PM
schlepprock250
29
Mar 13, 2010 01:25 PM
The Conqueror
Nov 4, 2007 07:37 PM
wisebeard
Oct 5, 2006 08:20 AM
