Sponsored by: Real Truck
steering issue
Old Sep 7, 2011 | 01:56 PM
GR$$N$'s Avatar
GR$$N$
steering issue
i have alot of play in my steering wheel.can go from about 10-2 with no wheel movement. i changed out my balljoints,tie rods and tie rod ends with moog about 10k miles ago.it got alot better from when i first bought it but now its loosening up a bit.do you think its the steering box because thats tightened all the way in already when i checked it.also im pushing 40s on a stock steering box so that'd be my assumption.any other ideas?
Old Sep 8, 2011 | 02:31 PM
jasoncw's Avatar
jasoncw
That would be my guess as well. I would get a Read Head gear box.
Old Sep 8, 2011 | 03:06 PM
sesh1975's Avatar
sesh1975
Mine is the same way. Time for a gear box.
Old Sep 8, 2011 | 04:15 PM
mountie's Avatar
mountie
Have some turn your steering wheel while you watch from the front where you can see both. Have him stop and start several times turning real slow and watch the pitman arm real close. Then you'll know. Good luck.
Old Sep 10, 2011 | 10:50 AM
trinibob's Avatar
trinibob
How do ya tighten up the gear box?
Old Sep 15, 2011 | 02:38 PM
GR$$N$'s Avatar
GR$$N$
guess im going to have to try buying a new one and hope it works.thanks guys. and trinibob there is an allen and i believe a 17mm nut on top of the gearbox but if you do it do MINOR turns and check.because you dont want to overtighten it and blow up the box
Old Sep 15, 2011 | 02:56 PM
trinibob's Avatar
trinibob
Thanks will do
Feb 23, 2018 01:12 PM
XTfx4
Jan 27, 2012 01:46 PM
Matt In Detroit
1978 - 1996 Big Bronco
25
Feb 19, 2011 07:51 AM
afonda
18
Feb 28, 2009 07:51 AM
13MWZ
Nov 24, 2007 05:38 PM
