2002 mountaineer
Old Jan 24, 2016 | 06:55 AM
Shiloh58's Avatar
Shiloh58
Question 2002 mountaineer
My 2002 mountaineer, 2WD, 4.0, suddenly started downshifting or appearing to go into neutral by itself. A scan showed no signal from the rear speed sensor which i had replaced. Problem still exists. If I manually put it in 3rd instead of drive, no problem except i can only drive 40 MPH as RPM's gets too high. Does this sound like a transmission problem? I just had a factory remanufactured transmission put in about 8 months ago. I haven't had it rescanned yet but I'm wondering if "no signal" could mean it the problem was something like the wiring harness instead of the sensor itself? Appreciate any feedback.
Old Jan 24, 2016 | 09:16 AM
Conanski's Avatar
Conanski
No.. you do not have a transmission problem, it is controlled by the same PCM that controls the engine and speed input is a critical parameter for trans control. So it is likely you have a problem with that signal elsewhere besiides the VSS sensor, it could be in the wiring harness but it could also be with the PSOM(Programmable Speedometer Odometer Module), have you noticed any issues with the speedo or ODO? Blinking display? Bouncing needle?
Old Jan 24, 2016 | 09:22 AM
Shiloh58's Avatar
Shiloh58
Conanski, Thanks for the reply. I have had no issues with speedometer nor the OD light blinking. One thing i forgot to add was that it usually downshifts when i let off the gas...almost like someone shifted down 2 gears.
Old Jan 24, 2016 | 10:06 AM
Shiloh58's Avatar
Shiloh58
I'm new to site so I''m not sure of correct way to reply. There has been no blinking OD light, no problems with speedometer (that i have noticed). The ABS light has been on for over a year. Also, when i drive it in 3rd gear it works ok but i can hear a fairly loud whistle that corresponds with the RPMs. When i let off the gas the whistle stops.
Old Jan 24, 2016 | 11:24 AM
xlt4wd90's Avatar
xlt4wd90
The transmission control does take input from the brake system, so that has to be functioning correctly or the transmission may not shift properly. At the very least, the transmission probably was not engaging the torque converter lockup during the whole time that the ABS light was on.
I would find out what's causing the ABS light. If there's a way to run a self test on it to get error codes, I would start there.
Deluxe46
Sep 12, 2019 10:17 PM
Elbovis
Aug 1, 2012 01:54 PM
why165
Aug 7, 2010 10:13 PM
derekmj64
16
Nov 27, 2007 09:02 PM
CF-DRG
Nov 7, 2006 05:17 PM
