Head Stud Install
Old Jan 21, 2016 | 10:16 AM
BigRedTed's Avatar
BigRedTed
Head Stud Install
I Have two questions on your guys opinion on installing studs. Does the 6 oclock dowel position really matter? To me it doesnt make much sense because the timing isnt changed with just studs so there should be no issue with valve clearance and such. Unless something isnt installed correctly.
Also what is the best way to clean the block? I thought Senior Master Tech on youtube had an interesting way with a piece of angle iron.
Old Jan 21, 2016 | 10:22 AM
Per4mance's Avatar
Per4mance
Ummm.........ya,if you don't want bent push tubes and valves. I suggest you read a lot before you do this to get familiar with this engine. It is basic but it has it's "quirks"
Old Jan 21, 2016 | 01:19 PM
run6.0run's Avatar
run6.0run
Old Jan 21, 2016 | 01:20 PM
BigRedTed's Avatar
BigRedTed
I've read a ton on this but I was asking because DieselTechRon has a video and he says its never mattered and to me it makes sense. The shop I have a good relationship with said the same. I was just curious if people actually have issues or if it's just something people do.
Old Jan 21, 2016 | 01:21 PM
BigRedTed's Avatar
BigRedTed
Old Jan 21, 2016 | 03:55 PM
Per4mance's Avatar
Per4mance
I've said it once and I'll say it again"
it's your truck and your money,do what ya want","but time is money and I just don't have the time to do it twice"
Old Jan 21, 2016 | 06:02 PM
Splash67's Avatar
Splash67
I agree 100% and now I'm paying for the fact that I didn't follow that advice.
When I tore down mine to do the heads the only thing on the top end that I didn't rebuild or replace was the HPOP and now 20k miles later it's blown also.
So I guess my point is, don't cut any corners and make sure that you are doing everything that needs done, don't just stop at HG and studs.
Old Jan 21, 2016 | 08:55 PM
BigRedTed's Avatar
BigRedTed
Did you remove the airbox? How hard is it to remove?
Old Jan 22, 2016 | 10:08 AM
r2millers's Avatar
r2millers
You have to remove it to access the FICM and then remove it to access and remove the valve cover.
Removing the airbox is the easy part of starting this process.
Old Jan 22, 2016 | 10:19 AM
BigRedTed's Avatar
BigRedTed
Sorry were you thinking air filter box? I meant the a/c heater box on the passenger side. I have removed the air filter before haha. I've seen some that claim they can get the passenger head out without removing it but that seems quite difficult
Old Jan 22, 2016 | 10:40 AM
texastech_diesel's Avatar
texastech_diesel
Token Redneck
You can take the cover off the evaporator housing box without removing it entirely:
https://www.ford-trucks.com/forums/1...b-on-hint.html
DIY bracket to rmove the heads with an engine hoist, if you rubber band the studs in this should make it easier to set the head straight down onto the alignment dowels:
https://www.ford-trucks.com/forums/1...l#post12575219
Old Jan 22, 2016 | 01:14 PM
Splash67's Avatar
Splash67
Yes I did. I've read about others not taking it out, but I can't imagine doing it with it still in. You'll also need to get torque extender to reach the bottom bolt on the driver's side next to the firewall.
Ranger GT2
19
Feb 13, 2021 08:46 PM
minnesota-clint
Feb 23, 2015 10:27 AM
amd_038
Jun 14, 2012 09:18 PM
Baddfx4
Aug 28, 2007 01:03 AM
