Hydra mount/bezel? Really?
Old 11-29-2016, 10:44 AM
Sous's Avatar
Sous
Sous is online now
Received 4,515 Likes on 2,874 Posts
Not from my end. I bought a F5/F6 mount from RiffRaff that was made/designed by DP. Please see the information below.
F5 & F6 EX Switcher Mount - Riffraff Diesel Performance
I then painted the bracket and cable to the Hydra controller to match the beige paint of the interior.
I would suggest ordering from RiffRaff if you go this route as shipping was ~$2 where it would have been ~$15 from DP to my house. Despite the fact that DP is 50 miles down I-85 from me the shipping was 7 times what it was from RiffRaff in Oregon.
I am very happy with the product and how it keeps the controller out of view when needed, but still provides a method of changing or checking the tunes.
  #62
Old 11-29-2016, 11:05 AM
Gaugepro's Avatar
Gaugepro
Gaugepro is offline
The Hydra switch doesn't fit the DP mount from what I have seen?
  #63
Old 11-29-2016, 11:11 AM
Sous's Avatar
Sous
Sous is online now
The one I posted from RiffRaff/DP does fit because it is an open design and not a flush mount. Although, I believe you are right in that the flush mounts for the F5/6 do not play well with the Hydra.
  #64
Old 11-29-2016, 11:22 AM
Tugly's Avatar
Tugly
Tugly is offline
...How many is A LOT?
I can see where he'd need to sell about 1000 units to get the price reasonable - and to just break even on the venture. If this were a fancy device he could get $100-$300 dollars out of, it would be one thing - but this is a small bezel. How much is everybody willing to pay for it to avoid the other options? It's 15 bucks for the RRD frame.
  #65
Old 11-29-2016, 11:31 AM
Sous's Avatar
Sous
Sous is online now
I am no businessman and might be out of line here, but perhaps a call to Clay (RiffRaff), Corey (CNC Fabrication), GearHead, PHP or anyone else that sells Hydra's at a decent volume to help get the product made and selling would be the right answer.
  #66
Old 11-29-2016, 11:42 AM
akcooper9's Avatar
akcooper9
akcooper9 is offline
Are you trying to have the bezel machine out of aluminum? Have you thought about having them done in plastic?
  #67
Old 11-29-2016, 12:01 PM
Gaugepro's Avatar
Gaugepro
Gaugepro is offline
Originally Posted by akcooper9
Do you have a contact number I can reach you at? For some reason I can not PM you???
IIRC you have to have a set number of posts before FTE will allow you to PM. I can not PM you as of now.
  #68
Old 11-29-2016, 12:03 PM
akcooper9's Avatar
akcooper9
That must be it. I only have 3 posts. Just found your FB will call. Thanks
  #69
Old 11-29-2016, 02:08 PM
Stewart_H's Avatar
Stewart_H
Stewart_H is offline
It does not. It has to be modified to fit.
Originally Posted by Stewart_H
...when I switched from the F6 to the Hydra, I customized the Hydra switcher to make it fit.
I grabbed my belt sander, flipped it over, and then just kept sanding the edges of the switch box and test fitting until I got enough material removed to allow me to wedge the box into the mount.
Stewart
Stewart
  #70
Old 11-29-2016, 02:09 PM
akcooper9's Avatar
akcooper9
Stewart
Do you have a picture of it?
  #71
Old 11-29-2016, 02:12 PM
Stewart_H's Avatar
Stewart_H
Do you have any pictures or test models that you can post? Although, this may infringe on the FTE guidelines.
How many is A LOT?
Please do be mindful people. Sous is correct in needing to tip-toe so as to not infringe on any SV toes who pay to advertise here.
Stewart
  #72
Old 11-29-2016, 02:14 PM
Stewart_H's Avatar
Stewart_H
I'll snap one later with my phone and post it.
Stewart
  #73
Old 05-09-2017, 08:57 PM
Gaugepro's Avatar
Gaugepro
Gaugepro is offline
Looky here...
  #74
Old 05-09-2017, 09:00 PM
akcooper9's Avatar
akcooper9
Looky here...
i want one!!!!
  #75
Old 05-09-2017, 09:21 PM
white Buffalo's Avatar
white Buffalo
white Buffalo is offline
Well, let's not be selfish and keep it a secret. Fess up and let the forum know how to get one.......
Quick Reply: Hydra mount/bezel? Really?
