hello it has been a while
Old Aug 8, 2003 | 11:52 PM
cobraii's Avatar
cobraii
I have been out of touch for a while but I thought I would share that I took my 51 for a spin around the block yesterday and boy did that feel good. A couple more good runs like that and maybe I will start the sheet metal work.
Couple of questions though?
1. When I was going around the corners the rear end felt lose what would cause that feeling?
2. When I put mty hanging pedals in I put the master cyl from the donar viechle witch was a 77 mustang and I was wondering is there a larger size of master cyl that would fit those pedals?
ps I added some picts to the gallery check it out.
Old Aug 9, 2003 | 12:11 AM
41Clay's Avatar
41Clay
Nice pictures, but is there and outside to the truck? That "brace" is used right above the radiator to keep the air going throught the radiator and not around the top. I threw mine out because my new radiator does that job it's self.
The rear end might be due to low tire pressure. Don't know about the master cylinder though.
Doesn't it feel great to take it out again after a long time of being away?
Clayton
Old Aug 9, 2003 | 01:16 AM
mtflat's Avatar
mtflat
I put a couple of pictures of the air baffle/brace under the hood of my '48 - hope it helps some........
When I was driving the '48 without front fenders and box it felt squirrely too. Disappeared when I got the weight of the box on it.
Sorry, I haven't done the dual reservoir mc yet.
Old Aug 9, 2003 | 12:26 PM
cobraii's Avatar
cobraii
Hey there I added some picts of the outside
And it does feel great to actualy drive the truck because I had not ever driven it before.
Old Aug 9, 2003 | 01:21 PM
bobj49f2's Avatar
bobj49f2
If you are using the stock radiator in the stock postition the eight cylinder brace is sit closer to the cab and six closer to the front. There are two different shields, the eight is wider and the six is narrower because of the postition in the hood. I hope this helps.
hillgilley
Nov 14, 2014 08:21 PM
MavSprint
Feb 3, 2013 04:11 PM
johncart
Nov 15, 2010 06:40 AM
DT 466Man
Jun 27, 2005 07:57 AM
hawk_eye
Jun 17, 2001 02:16 PM
