Power Brake Booster?
Old Feb 2, 2013 | 10:30 AM
MavSprint's Avatar
MavSprint
Someday I intend to do the CV tront end transplant into my '70 2WD, manual brake F100. When that happens, I'll want a power brake booster. But, I'll be driving the truck for a while with the original F100 front end.
The truck needs a master cyl now and I'm wondering if it makes sense to install this Buy Cardone Remanufactured Power Brake Booster With Master Cylinder 50-3515 at Advance Auto Parts now and use it initially with the stock F100 brakes and later with the CV brakes.
The booster will bolt up to the firewall in the same way that the original '70 master cyl does, right?
Would the Cardone booster/master cyl be for front disk brakes or did a F100 come with power all drum brakes? Either way, would it be a problem to use that master cyl with the original front drum brakes?
Will the brake rod be OK with the F100 manual brake pedal? If not, does the rod pull out of the booster like the rod pulls out of a master cyl? If it uses the same kind of rod, I expect an adjustable rod would handle any difference in length.
Any advice or comments will be appreciated.
Jim
Old Feb 2, 2013 | 02:25 PM
flyboy2610's Avatar
flyboy2610
I am assuming that the F100 has the factory drum brakes all around, and the CV front end has discs on the front?
If so, the MC for a disc/drum system is different for a drum/drum system. They have different internals. I do know it not wise to use a drum/drum MC for a disc/drum system, but I am not sure if it would affect safety to use a disc/drum MC for a drum/drum system. If it IS safe, you can get a disc/drum MC and booster. Somebody else may be able to help with this point.
Regarding mounting, the booster needs brackets. It will not mount up to the studs used for the MC.
Here is a pic of the brackets, as I was installing them on Frodo, my '69 F250:
These brackets can be found at salvage yards, or you could probably snag a set from someone here.
Or you can get them here: (about halfway down on the right side of the page)
Flashback F100's - New Products************ This page has new parts that have just come on the market*
Old Feb 2, 2013 | 03:13 PM
MavSprint's Avatar
MavSprint
That helps. Interesting web site too. The different brackets listed for different years lets me know some newer brackets won't work fit on the '70.
I believe at least some drum brake master cyls have residual valve(s) to keep the shoes near the drums, which aren't helpful with disks. Also believe some residual valves can be removed. Something to think about for sure.
I'll look for some brackets.
Thanks.
Old Feb 2, 2013 | 03:54 PM
flyboy2610's Avatar
flyboy2610
You are most welcome.
Old Feb 3, 2013 | 12:36 PM
MavSprint's Avatar
MavSprint
Jim
Got the answer to the first question. Anyone want to help with the 2nd and 3rd?:
. Were power brakes with front drums available on the '70 F150?
. Will the rod attached to the booster be OK when attached to a manual brake pedal?
Old Feb 3, 2013 | 01:09 PM
flyboy2610's Avatar
flyboy2610
Yes to both questions. Front discs were not available on the F100 until 1973, and then they were standard equipment. Get the proper booster for your year of truck and you should be fine.
Old Feb 3, 2013 | 04:11 PM
MavSprint's Avatar
MavSprint
Ok, thanks.
idealtrucks
Oct 19, 2016 05:50 PM
andrew's64
Jan 10, 2016 05:18 PM
SeaBeeCm1
Jun 11, 2011 08:23 PM
Broken40
Aug 19, 2007 06:00 PM
user 5363849
May 24, 2002 01:14 PM
